Disconnected battery, not pre-collision and other warning systems not working...
Discussion in 'Gen 4 Prius Main Forum' started by GRF819, Oct 30, 2022.
  1. GRF819
    GRF819 Junior Member
    Los Angeles
    As I have done with previous Prius models, I disconnected the battery because I was going away for 2.5 months. When I returned, I hooked up the battery, which seemed fine, but the physical warning systems, like pre-collision system, do not work. I have checked to make sure they are on. Any guesses as to the problem? Thanks!
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Are they throwing error codes? If not, how did you determine that they are not working?
  3. Mendel Leisk
    41,911
    Just in case: check voltage of the 12 volt, with a digital multimeter, first thing on the morning. If practical, pop the hood the previous evening, or at least enter car from passenger side to pop hood (avoids waking up brake system, dropping volts slightly). Post reading; anything over 12.5 would be satisfactory I’d think, 12.7 or higher is tip top.
    Mambo Dave likes this.
  4. Doug McC
    Doug McC Senior Member
    1,082
    421
    Midwest
    2022 Prius
    Check your owner’s manual under “If 12 volt battery is discharged” (specifically “When removing 12 volt battery terminals”) and under “Items to initialize. In the 2022 manual these are found on pages 646, 648, and 697.
