Disconnected the EV mode speaker
Discussion in 'Prius c Accessories and Modifications' started by rumpledoll, Mar 10, 2013.
  1. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    Wanted to restore the nice silence in EV mode, just like my old 2007 Prius and my wife's current 2010 Prius. The speaker is located on the divers side. I had to get at it from below (after loosening the access panel), someone with tiny hands might be able to get at it from the top. Just one wire harness to unclip and much less noise in EV mode.
    Dylan Murphy likes this.
  2. DoPeY5007
    DoPeY5007 Member
    122
    17
    I believe it is required now, don't think a cop will ticket you for it, but it is a safety item for others.
    Personally I think you should leave it there and on.
  3. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    You could save a little gas over the life of the car by removing the speaker entirely. If I had a prius it'd be the second thing I did after removing those atrocious wheel covers... :) Making a quiet car noisy is ridiculous. It's also why they made horns in the first place... You honk at them if someone doesn't see you. Or better yet just play really loud music on your real speakers! And yes I understand why the car maker needs the stupid speaker for liability reasons, but if you're about to run over someone maybe slow down and give 'em a gentle honk so they get you of your way instead?
  4. DoPeY5007
    DoPeY5007 Member
    122
    17
  5. PriusCamper
    13,403
    5,412
    It is a requirement that's easily disabled, just like the reverse beep. And yes its more dangerous, just like driving over the speed limit is. But sometimes breaking the rules is sensible and much more peaceful...
    finman likes this.
  6. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    Car is much better now, quiet just like my 2010 Prius and just like my 2007 Prius was. Now I'm a bad boy rebel just as all those thousands of pre-whenever this silly noise maker was installed Prii!
    dogfriend and PriusCamper like this.
  7. DoPeY5007
    DoPeY5007 Member
    122
    17
    You can hardly hear it from with in the car.... Ignorant to remove it.
    ewaboy and JMD like this.
  8. bisco
    52,773
    it's a requirement to install it, not for owners to keep it... yet.:unsure:
    PriusCamper likes this.
  9. PriusCamper
    13,403
    5,412
    Sometimes I'm tempted to sell all the garbage that my car used to have in it. Other times I'm inclined to keep it all to improve resale value.
    rumpledoll likes this.
  10. PriusCinBlack
    PriusCinBlack Member
    145
    61
    No, it's not a matter of criminal law for a car owner, I don't believe. However, if someone was to hit a pedestrian with the feature disabled, that would be the pedestrian plaintiff's primary evidence in a negligence (or higher standard) lawsuit. Since the removal was done purposefully, other standards (like "willful and wanton") could potentially be met and potentially leading to higher damages.
    Just giving fair warning that it's not criminal but civil liability that's a worry for doing this.
    On edit: I'm not a lawyer- take everything I said about the standard of care (i.e., "willful and wanton") with a grain of salt. Just know that conduct purposefully setting up more dangerous situations than were previous tends to be more liable in the law than those that are unforeseen and purely accidental.
    ewaboy, JMD and ftl like this.
  11. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    What's the big deal. It is a safety device.
  12. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Speaking as someone who didn't get this feature because I don't live in the US, I haven't found there to be much issue.
    First and foremost, as a driver, I have primary responsibility to not hit pedestrians. There are some situations where a pedestrian can contribute to a collision (eg. willfully running into a road without looking) but I still have to be on watch.
    If I'm in an area where people are less observant, I adjust accordingly.
    The only time where I think this is a truly valid issue is in car parks and even here most people notice the light from my LEDs and realise I am there. If they don't, I stop or stay behind them, but to be honest I think I may have surprised only 2 people in 7 months. I didn't hit them because that's my job as driver.
    kevtan and Dylan Murphy like this.
  13. JMD
    3,779
    1,282
    The Pedestrians have rights also
  14. fuzzy1
    10,687
    Not yet:
    "Jul 8, 2011 ...
    The new regulation, however, is a long way off. NHTSA has until next July 4th to write the specific standards in the noise regulation, and until January 2014 to publish the final rule (which likely couldn’t take effect for another year after that.)"
  15. poser
    poser Junior Member
    Alberta
    Well, I have hit a pedestrian once and it does not only happen to others. Trust me, that's the last thing you want to do. There are times when the stars align just the wrong way and someone gets in the way of your car. Sunshine, busy traffic, you name it, if you spend a fraction of a second too long on one "high risk" situation at an intersection, you have one less fraction of a second to look around you. Speed isn't always a factor and if I could, I'd make the EV speaker louder!
    My .02
    GrGramps, RocMills and JMD like this.
  16. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    Great! Now you will be able to hear the screams when you run over pedestrians!
  17. PriusCamper
    13,403
    5,412
    If anything is going to make it easy to kill a pedestrian in a Prius it's those darn steep angled pillars on both sides of the windshield. Total blind spot... I've thought of plastic-dip for the light beige plastic covers just to limit the glare they create on the windshield and side windows. A pedestrian can easily not be seen (at least in Gen2) behind one of those steep angle pillars. It freaks me out all the time!!!
    vdefender and rumpledoll like this.
  18. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    I will often choose my pedestrian killing tort acquiring danger mobil, aka my Prius V 2010 which never came with a sound making device. All the people who have kept their pre-noisemaker Prii are such savages! Trade them in immediately. Don't get me started on the dangers of golf carts...
    vdefender and ufourya like this.
  19. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    Agreed.
  20. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    I note the manual mentions the VPNS turns off when you exceed approximately 16 mph (25 km/h), or if the ICE is on. I'm really wondering what people are doing to not be aware of what is crossing their path within their stopping distance at or below this speed.
    I've only been driving the c for 7 months and perhaps I've been looking out for it - knowing that VPNS was not fitted to my vehicle - but to be honest, people used to walk dangerously close to my car just as often if not more often with my old Corolla than they do with my c.
