Disengaging the Horn While Locking/Unlocking
Discussion in 'Prime Technical Discussion' started by Eric J, Aug 29, 2020.
  1. Eric J
    Eric J New Member
    Los Angeles
    How do I disengage the horn when I lock and unlock the doors?
  2. Tideland Prius
    16,683
    By default, the horn doesn't sound when you lock/unlock (just a beep).
    If that's what you're referring to, you need to either go to a dealer or get an OBD-II reader and app to customise the settings. You can check your owner's manual to see what is customisable by you (via the MFD) or what is customisable only by the dealer.
    jerrymildred likes this.
  3. markrivers
    markrivers Junior Member
    88
    Beverly Hills
    2020 Prius Prime
    +1 unless your dealer added an 3rd party alarm on it.
    you should only hear a beep
  4. Eric J
    Eric J New Member
    Los Angeles
    Its definitely a horn not a beep. It’s 2 horn sounds(beep beep) not a digital sound
  5. Eric J
    Eric J New Member
    Los Angeles
    Definitely a horn sound (Beep Beep) not a digital Beep.
    It does make the digital beep simultaneously with 2 horn beeps while locking and unlocking the doors.
    #5 Eric J, Aug 30, 2020
  6. Tideland Prius
    16,683
    If you bought it used, it's possible the previous owner enabled the horn by modifying it. I looked in the owner's manual and there's no option for horn, just the beep (or buzzer as the term the manual uses).
  7. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Yeah, and it's not listed in Carista either, I have it and I checked. You can lower the volume of the beeps in the center screen settings, that's it. Ask your Toyota dealer and as mentioned above, look for aftermarket parts. Maybe under the dash.
  8. Eric J
    Eric J New Member
    Los Angeles
    Thank you very much
    Thank you very much
    #8 Eric J, Sep 1, 2020
