display panel, radio lights
Discussion in 'Gen 3 Prius Technical Discussion' started by countrygirl, Oct 5, 2012.
  1. countrygirl
    countrygirl Junior Member
    30
    Huntersville, NC
    Is this normal for a prius. I have owned mine for about 3 weeks now and have noticed something strange. Watching the instrument display and the radio. As I am driving, I notice that every once in a while the light would dim down some and then later brighten back up.
    Thought I would see if this is normal before I go and bug the guys at Toyota.
  2. 50324prius
    50324prius Junior Member
    39
    iowa
    Does it get as dim as when you turn the headlights on? What is the brightness outside when this occures? Is there any variance in the light outside when it happens?
    I would set the adjustment wheel to full brightness and see if it continued
  3. countrygirl
    30
    Huntersville, NC
    Turning on the headlights doesn't affect it at all. I have the dial set to full brightness all the time. The weather here has been sunny, cloudy, rainy, etc....
    Seems to happen no matter what the weather is doing.
  4. 50324prius
    39
    iowa
  5. fuzzy1
    10,722
    It has some sort of automatic brightness adjustment, depending on the ambient light. I see it most in tunnels or darkly shaded areas. This is new for 2012, my 201o didn't do this.
    Owner's manual, p. 217:
    "Brightness of the instrument panel
    If the headlight switch is turned on while the surrounding area is dark, the instrument panel lights will dim."
  6. countrygirl
    30
    Huntersville, NC
    That does sound like an explanation. Wonder why though. Seems like you would want it to be brighter in dark areas.
  7. User37
    User37 Can spell PRIUS
    83
    Italy
    Yes, it is normal. There is a sensor in the front right of the dash, near the corner where the glass reaches the dash.
    The illumination is dimmed in three or four steps. Not every time the steps fit to the light conditions, but in general it is ok.
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Bright lighting in dark area will hurt your night vision. You want them bright in bright daylight so you can see them.
