Ditching the bulky keyfob- How?
Discussion in 'Prius c Technical Discussion' started by bostono, Apr 19, 2013.
  1. bostono
    bostono New Member
    Hey-
    I truly hate the prius c keyfob. Its massive. Im wondering if there is a way I could get a key made, which would just be the manual key to unlock the door and then I could just hold said key next to the start button to excite the circuit and start the car.
    Or, Is there a aftermarket, smaller keyfob available that works with our cars?
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    No.
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    uhh.. the smart key doesn't require you to hold the key next to the start button unless the battery in the key is dead..
    you don't even need to remove it from your pocket.. and the smart key is a decent size compared to a regular car key.. and it's as small as it's going to get with the circuitry.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep on the above.
    If the OP doesn't know that, then the dealership did a very poor job of explaining the car to the OP.
  5. fuzzy1
    10,674
    Does the 'c' use the same smart key as the Liftback?
    If so, a possible solution is:
    * Remove the battery and the little mechanical key from the fob;
    * Hide the fob inside the car, where you can quickly fetch it to hold against the Start switch for starting;
    * Take the mechanical key with you, to lock and unlock the door. This key is smaller than a regular car key.
    karabits likes this.
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    The c can be had w/o SKS.
  7. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    If you are carrying it around in your pockets I find it is the perfect size to go in those useless pockets in mens pants that are inside other pockets. For instance the side pockets on all my pants have the normal pocket, and then this dinky pocket inside of it near the top. It is the perfect fit for the fob, and I have a flash drive on mine too.
  8. cknfts
    cknfts Junior Member
    69
    71
    ztanos likes this.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    OOH YOU FANCY!!!!:D
    BigWIll and cknfts like this.
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Correct, but the OP has a 3 which cannot not have the SKS.
  11. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Actually the C3 and C4 have SKS, which I guess is also why the OP mentions the "start button". :p
    I don't actually think the SKS fob is large... and mine lives in the bottom of my pocket, where I do not think about it. Goes in when I leave the house, comes out when I return home. I don't think mine would fit comfortably in my coin pocket, it'd be a bit of a squeeze.
  12. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    ... which is why I said it can't NOT have it...
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I keep trying to walk up to my house and expecting it to open... stupid door knobs... :LOL:
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Star Trek doors!
    RocMills and ztanos like this.
  15. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    It doesn't help that my work uses rfid sensors to unlock the door. I just have to get close to them and they unlock...:oops:
  16. cknfts
    69
    71
    ztanos likes this.
  17. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Oops... I missed the double negative.
    ztanos likes this.
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The keyfob case is mostly there to protect the much smaller circuit board. Lexus has thick credit card cases as an alternative to their massive keyfobs. Perhaps you could fashion a smaller case to protect the ordinary circuit board.
  19. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    You sometimes gotta wonder about the OP. The post was made last Friday and he hasn't even returned after that day.
    I'm not sure it's worth discussing until he returns.
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I like this idea. Being able to just put it in my wallet and forget about it would be very nice.
