Ditching the bulky keyfob- How?
Discussion in 'Prius c Technical Discussion' started by bostono, Apr 19, 2013.
  1. bostono
    bostono New Member
    Sorry for the delay.
    To answer some questions:
    1: The reason I mention holding it next to the start button is because there is circuitry in there which can excite the keyfob (or mechanical key) if the battery is removed, to make it smaller
    2: the keyfob container itself is huge compared to the internal circuitry. I thought about making a custom case for it thats 1/2 the size but I am not particularly handy. I suppose I could just dip it in a plastic resin with a basic mold. The keyfob without the container is about the size of a mini box of matches.
    3: I dont believe the lexus keycard is compatible
    4: My thought at this point is to indeed just leave the keyfob part without the battery in the prius in a hidden spot and just carry the key with me. Rather lame way to do it though. The reason you cant keep the battery in the keyfob is that anyone could just come and grab the car that way. I suppose I could make a custom metal walled box to take it out of, but I think the keyfob with no battery is safer as most criminals would not know you need to hold it near the start button to start.
    5: The original question from me was poorly phrased, but basically: Is there a key I can get which only has the circuit that can be energized by being near the start button? This is similar to other 'chipped' keys, so I am assuming it should be possible
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    As I understand it, there is a second, but perhaps more important reason not to leave
    a powered SKS key inside the car for long periods when it is not in routine use. IIRC,
    when the SKS key is in the car the recieving antenna in the center console alerts the
    computer(s) to the liklihood of an immenent start. The car then comes out of its
    normal shut down mode to a higher, get-ready-to-start standby mode. This places
    a higher than normal electrical load on the poor, little, weak sister 12 V battery and
    running it down... risking the always troublesome, and too often heard, 'My Prius
    wont start' syndrome.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Right. Which is why he mentioned pulling the battery out. At that point the car would only recognize it from the RFID tag when it was within inches of the Start button.
    Bear E likes this.
  4. Ghoti
    Ghoti Member
    101
    Arizona
    Somehow the prospect of leaving a key which can be used to start the car in the car at all times strikes me as a poorly-thought-out idea.
    Yes, the fob is larger than the circuitry itself, but like others are saying, the only time it even needs to leave your pocket is when the battery dies - which is several years' time. And it's no larger than the fobs I've had for other cars in the past. I guess I don't see what the big deal is.
  5. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Ditto! Much ado about nothing.
    About the only fobs that I've had in recent time that were smaller were the non-smart key (non-Intelligent Key) fobs that came w/my former Nissan Maxima and 350Z. New Pair Nissan Infiniti Keyless Entry Remote Key Fob Clicker Transmitter Beeper | eBay is an example of what those look like.
    The current Nissan Intelligent Key (their name for smart key) fobs are larger than the above.
    OT... I wonder how many people get your handle's reference to fish... :) I'm guessing that's how you pronounce it.
  6. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Aren't these moot points? If there's a powered fob in the car, it shouldn't let you lock it, at least not without some difficulty.
    Whole thing sounds a lot more painful than the fob you forget at the bottom of your pocket.
  7. fuzzy1
    10,687
    I can sympathize with OP. I don't like a lot of bulk in my pockets, and long ago slimmed down the primary keyring and wallet to just the frequently used and essential items. A secondary keyring and wallet carry the lesser used items.
    No other car in this household needs a fob. The Subaru had one for the remote door unlock / security system, not ignition, but that was dropped when the shock sensor began malfunctioning and had to be disabled to quit annoying the neighbors. Before getting around to fixing it, I learned that its radio protocol was no longer secure (non-rolling code), and it best be shut off permanently.
    The Prius fob is bulky enough that it is on a separate keyring from the other car keys. Both rings have their own house key. The spouse does the same.
  8. Ghoti
    Ghoti Member
    101
    Arizona
    Unsurprisingly few people get the right pronunciation as you have :)
    Nexus 4 ? 2
    ztanos likes this.
  9. bostono
    bostono New Member
    I dont have a keyring normally. My home lock is on a RFID system. My other one 'normal' key sits in a slot in my wallet. Its very annoying to have to carry something the size of a matchbox car with me everywhere I go, especially since I have a wallet in one pocket and my cellphone in the other. I also have to worry about it falling out of my pockets because of the size. I suspect many women dont care about the size of the keyfob because they have purses.
    I am going to test out the keyfob without a battery idea. If it works, I will remove the keyfob cover and just leave it in my car in the cupholder. Maybe I will put it in a tictac box or something to disquise it.
  10. fuzzy1
    10,687
    Do put it inside some sort of container, or cover, or plastic bag, to reduce static zaps to the conductors. While the risk from any one incident is generally low, repeated static discharges weaker than you can't feel may damage it over time.
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I don't put my Prius' (smart) key on any key ring. It sits by itself in its own pocket. Never had it fall out. I've never lost any car keys or key fobs ever since I've been driving (for >22 years).
    I'm a guy, so no purses for me.
    Yep. Static is the enemy.
    I personally wouldn't want to leave my smart key anywhere inside my car unless absolutely necessary, even w/o the battery. I certainly wouldn't want to risk damage to the fob either by removing and using it w/o its housing. They aren't cheap to replace and it's not cheap to get the car programmed to learn replacement keys.
  12. bhyde
    bhyde Junior Member
    Arlington, MA
    I agree with OP. The FOB is far too big. So, I too would love to see a smaller alternative. My thought is to remove the innards from the fob and place them into a smaller container, maybe 80% of the bulk appears to be unnecessary. More if your will to shift the location of the battery. If making duplicates wasn't so damn complex and expensive it would be easier (low risk) to try some DIY experiments.
  13. bisco
    52,751
    if anyone could pull this off, they would be an overnight success.
  14. bisco
    52,751
    same here, fob only. i've gone to keyless entry across my entire lifestyle.
  15. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    how you say...simple
    buy a 3d printer, design your own slimmer fob, print...and boom, there you have it
    I'm pretty sure you can easily recoup your 3d printer's pricetag by selling fobs to everybody that'll buy one
  16. bisco
    52,751
