DIY 12V Battery Replacement Add'nl Info
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elektroingenieur, Mar 17, 2018.
  1. Mendel Leisk
    42,347
    Just going by the voltage, looks it's still ok. But considering the age, I'd get an electronic load test. There are relatively inexpensive such testers available, automotive retailers often have them and will test for free, and dealerships as well have them, but will likely charge you, somewhere between $50~100. If I was buying one today it'd probably be Solar BA9. Ancel is another popular brand.
  2. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
  3. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Anyone tried a trickle charger to get volts on the circuit?
  4. Mendel Leisk
    42,347
    Not sure what you mean, in particular the part I made bold. Our ‘10 is low usage these days, and I keep the 12 volt battery on a smart charger pretty much constantly. I’m using a CTEK 4.3 (current iteration is called CTEK 5 IIRC; essentially the same AFAIK).
  5. ETP
    2,806
    1,170
    Auburdale FL
    Just during a battery swap.
    Anyway OBE! AutoZone did it without any issues on the 2019.
    Highlander is a bigger project when that day comes.
  6. sparky12
    sparky12 Junior Member
    22
    Virginia
    2021 Prius
    XLE AWD-e
    Just replaced mine. It wouldn't start and lights all over the place. Checked the battery and it was 9v. Got a DieHard that fits it (expensive as all get out). I live in the sticks so that's the only one they had. Did the fuel door thingy and drove straight for a few hundred feet or so and so far so good. Had to change the time but I did not lose the radio presets. I'll gradually get it back the way it was.
    I didn't have to replace the batteries on my 2005 and 2013 Prius'. I had them well over 7 years each.
    #126 sparky12, Sep 24, 2024
  7. sparky12
    22
    Virginia
    2021 Prius
    XLE AWD-e
    Ok, so what is the relationship between the traction batteries and the 12v battery? How does the 12v battery get charged as I'm not sure there is an alternator on this car.
    Before the battery died I was driving this vehicle (Wife's car I don't drive it much. Prefer my 16 Tacoma.) and noticed the charging on the traction batteries was all over the place. It never got to nearly full charge like normal. I can't exactly say what it was doing although it struck me as being a bit abnormal. The traction batteries would lose charge sitting still. After I changed the 12v battery out with a new one, the traction batteries went back to normal 'charging' as far as I could tell and no issues so far.
  8. Robert vickroy
    Robert vickroy Junior Member
    16
    Houston
    2018 Prius Prime
    By the way, you have to have the car keyfob to open the fuel door or disconnect the charging cable.
  9. ChapmanF
    19,025
    An electrical circuit powered by the car's high-voltage electrical system supplies 13 to 15 volts onto the car's low-voltage electrical system whenever the car is in READY. That powers the car's low-voltage equipment and accessories and keeps the aux battery charged.
  10. Robert vickroy
    16
    Houston
    2018 Prius Prime
    On a Plug-in hybrid Prius Plus Prime at least, there is a design flaw related to ICE Battery - it only charges when you run the ICE engine and not when you plug-in to charge the traction battery, just like any other car. The more your successful in running all-electric and trying not to use the ICE engine (my local driving lets me achieve 70% electric mode) the more likely you are to have a failed ICE battery - it seldom charges unless ICE engine runs and eventually dies with a bad cell. I put 5 ICE batteries (one every 18 months) in my 2018 Prius Prime Plus under battery warranty and dealer replaced them saying "I don't know why the battery dies". So if your ICE battery is still under warranty, take it back to the Toyota dealer for a free new one. You can also check the voltage every month and put it on a battery charger when its' getting somewhere below 11-12v, or buy a solar panel WITH A DIODE (to prevent reverse flow) that hooks to battery and lay it on dashboard.
  11. Robert vickroy
    16
    Houston
    2018 Prius Prime
    Not really.....On a 2018 Plug-in hybrid Prius Plus Prime at least, there is a design flaw related to ICE Battery - it only charges when you run the ICE engine and not when you plug-in to charge the traction battery, just like any other car. The more your successful in running all-electric and trying not to use the ICE engine (my local driving lets me achieve 70% electric mode) the more likely you are to have a failed ICE battery - it seldom charges unless ICE engine runs and eventually dies with a bad cell. I put 5 ICE batteries (one every 18 months) in my 2018 Prius Prime Plus under battery warranty and dealer replaced them saying "I don't know why the battery dies". So if your ICE battery is still under warranty, take it back to the Toyota dealer for a free new one. You can also check the voltage every month and put it on a battery charger when its' getting somewhere below 11-12v, or buy a solar panel WITH A DIODE (to prevent reverse flow) that hooks to battery and lay it on dashboard.
  12. Mendel Leisk
    42,347
    Even with the car "Ready" (aka "fully on")? If you're running electic-only, the 12 volt battery's not getting charged? I'm a little incredulous; that would run it down fast I'd think.
    Just editorial (and admittedly OCD):
    Each time you say "ICE engine" you're saying "internal combustion engine engine". Lose the "ICE", just say "engine"?
    #132 Mendel Leisk, May 18, 2026
  13. Robert vickroy
    16
    Houston
    2018 Prius Prime
  14. ChapmanF
    19,025
    You seem to have learned a couple different things that you are mixing together.
    There isn't any Prius model where the aux battery only gets charged "when you run the ICE". Whenever the word READY is lit up on the dash, the car's DC/DC converter is providing 13 to 15 volts and the aux battery is being charged, whether the ICE is running or not.
    The design issue you seem to be thinking of is about the plug-in charging circuit, and what happens when the car is OFF but plugged in. Because the car is OFF (no word READY on the dash), the DC/DC converter that keeps the aux battery charged while in READY is not in play. The plug-in charging circuit charges the traction battery—but can actually drain the aux battery if left plugged in too long, because some of the circuitry that monitors the plug-in charging situation is powered by the aux battery! :oops: It's in the owners' manual:
    Brian1954 and Mendel Leisk like this.
  15. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    H4 walmart agm 189.00 plus take 2020 in February was a orgnail battery 120 k miles 9 bellow 0 when it failed
