DIY AC Top Up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dave1UK, Jun 30, 2026.
  1. Dave1UK
    Dave1UK Junior Member
    87
    London, UK
    Active
    So I got my car over a year ago now, back in March where temps were pretty low, the AC blew cold air but only slightly, I haven't had the time or really a need to diagnose/fix it. However now with the current heat we are getting in the UK, heatwave after heatwave need to get on top of it. As it feels like it's basically not blowing anything cold at all.
    Read a lot of posts/forums here and elsewhere. There was a mention here that maybe the expectation from the system is a bit much, however, I air the car out whilst driving (several minutes windows down), turn on the AC, put on auto mode and keep the fans blowing slightly above half speed max and as that drops, I slowly incrementally drop the temperature to adjust. I still need to check the sight bubble and "diagnose". Also in comparison to other Prius cars that family members have sat in, they state they are super cold and AC kicks in immediately so clearly there must be something up, leak or low on refrigerant.
    Now I have 3 options, direct dealership for about £180.00, other garages £150.00 or mobile mechanics around £60.00-£100.00 or DIY route about £50.00.
    I am aware of the oil type that can be present in some refrigerants and which to avoid etc. Safest route would be dealership, however I don't want to end up spending £180.00 to find out there is a leak and not have a working AC. Doesn't make sense for me to go to other garages that are charging near dealership prices otherwise I would do that. In regards to mobile mechanics, I honestly don't believe they would have separate dedicated machines/pipes for normal cars/hybrids/refrigerants so some contamination would 100% occur which is not worth the risk.
    I will first do my due diligence and try to diagnose using the sight bubble if it's apparent that the refrigerant is low. Will look at purchasing just the refrigerant itself with no additives as found some online that are hybrid safe/don't have any additives.
    Has anyone gone ahead and DIY topped up their system?
    52,863
    Dave1UK likes this.
  3. Dave1UK
    87
    London, UK
    Active
    Agree with what he says, that's what the research I looked into stated as well.
    I spent the whole of yesterday trying to find pure R134a refrigerant to buy without additives which I was able to HOWEVER it isn't actual R134a but all these smaller cans are labelled as a "replacements" now after research into that, it turns out it's almost impossible to buy the actual stuff unless you literally buy a bulk cannister basically for shops/professionals. These R134a replacements contain a mix of butane gas etc and even some (even if they state no oil) do/may contain some oils...not only that but an actual reputable R134a company well known in the UK gives conflicting information whereby they state on their website it is suitable for hybrid vehicles, but their suppliers state it isn't...
    Anyway as it seems I am unable to source any actual refrigerant only option is going to a shop but then again who knows how clued up they are/ensuring as what you linked whereby Lech states checking what machine is used/wet dry indicator showing dry and stuff - at some bigger shops, you can't be present in the work area to monitor all that.
  4. Mendel Leisk
    42,355
    considering the consequences of a misstep , I’d just go with dealership.
    180 GBP converts to roughly $250 USD, $340 CDN, a little steep. I had a Canadian dealership quote $150 CDN, maybe pre-COVID. To be fair, when they were done, the service writer really tried it on, “explaining” all the extras. We settled around $165, and it really left a bad taste, all the grubby tactics.
    Dave1UK likes this.
