DIY Coolant Change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 72fordgts, Jan 11, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    I just refill them until it stops, that's just me :p
    Rebound likes this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    If Heisenberg were an auto mechanic.
    m.wynn and Raytheeagle like this.
  3. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Thanks, I was hoping I could just buy 1 gallon jug of coolant since I don't need to do the inverter but I guess I'll get 2.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Our dealer will take back unopened bottle of coolant. You might ask yours.
    Jkan2001 likes this.
  5. Mendel Leisk
    42,355
    He's going to need to crack the second bottle though, by all reports, it takes one-point-something gallons.
    Addendum: ok, I see your point now: if he gets two but manages to squeak by with one bottle, he could possibly return the second.
  6. ms372591
    ms372591 Junior Member
    Maryland
    How far do you need to turn the bleeder valve for it to open? I turned it maybe 3/4 way around and did not get anything out while refilling. Does the engine need to warm up first?
  7. Mendel Leisk
    42,355
    This is in my experience with other cars, hopefully still the case with Prius:
    If the bleeder valve is open enough to be effective, as you are filling with fresh coolant mix, you'll feel a strong gush of air coming out of the valve, then coolant will start coming out.
    ms372591 and Tbkilb01 like this.
  8. Liam howard
    Liam howard Junior Member
    56
    24
    United States
    Four Touring
    Im going to be performing the coolant change on the ICE system and the inverter system with a Mity-Vac. I read the manual and it clearly states that I need at least 90psi of air to perform its function.
    Question:
    I picked up a 3 gallon pancake compressor that rates at 100psi. 2- jugs of undiluted Genuine Toyota SLLC Will I be able to perform the job correctly? Any suggestions?
  9. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Did mine without compressor
  10. ChapmanF
    19,038
    That's ok for psi (pressure), but any venturi vacuum pump (like the Mity-Vac) will also need a certain air flow (there should be a rating in SCFM) to develop its rated vacuum. That number ought to be in the Mity-Vac literature somewhere (or available by asking them). You might find the rating on your compressor to be too small for that; Mity-Vac probably designed their venturi for shops that have a big shop air system.
    I have done coolant changes both ways, and currently, with my Gen 3, I have reverted to just-pour-it-in-and-bleed like the old-school fossil that I am. It's not really that bad (in Gen 3, anyway; Gen 2 might be harder to bleed).
    The vacuum-fill approach seems really cool, but you do a bunch of prep (bring out the compressor, arrange the valves and hoses, make sure no air's in the hose and the coolant supply is higher than the system, etc.) and then there's the moment you say "here goes!" and twist the valve and watch it slurp in, and it turns out that various minor oversights in your prep will mean that you still have air in the system needing to be bled anyway. It's dandy when everything goes right.
    Liam howard and CR94 like this.
  11. Liam howard
    56
    24
    United States
    Four Touring
  12. Liam howard
    56
    24
    United States
    Four Touring
    Just checked the user manual for both compressor and the Mity-Vac. The compressor is rated at .6 SCFM @90 PSi. Cannot find anything regarding the rating for the Mity-Vac. I will call them when I get a chance.
    Is the Venturi effect analogous to blowing across the top of a drinking straw that is submerged in liquid in which the flowing air creates negative pressure inside the straw, forcing the liquid upwards? If not, how exactly is it achieved?
  13. ChapmanF
    19,038
    Exactly:
    If you assemble your own "vacuum coolant refill" rig and buy the venturi directly from an industrial supplier like Vaccon, you'll have access to complete specs on your venturi, and even the ability to choose a low-flow one better suited to your compressor capacity. Some of the Vaccon models will work at a lower, 60 psi pressure, where your compressor can probably do better than .6 SCFM, and if you find one that matches the available flow rate, it would take longer to evacuate your cooling system, but develop better vacuum. A venturi designed for a higher flow and used on an inadequate compressor just won't achieve as much of a vacuum as you want.
    The AirLift/MityVac systems will have a lot of patent numbers splashed across them. In my understanding, the only currently live patents cover details like how their fancy multi-radiator-neck-size fittings work and such. The basic idea of using vacuum to refill a cooling system goes way far back, and I don't think you can infringe it by using, say, a venturi pump, basic hoses and rubber stoppers. Some time ago I did more research and posted that in another PriusChat thread, but don't have time to search for it. I am not a patent lawyer. Or any kind of lawyer.
    Liam howard likes this.
  14. Liam howard
    56
    24
    United States
    Four Touring
    Thank you for taking the time to share the info. I just got off the phone with Mity-Vac and they said that the SCFM rating is not stated anywhere in their literature. So I guess this will be a fun experiment. Will definitely report back my findings!
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did both engine and inverter coolant changes on mine at our meet ups in the last 6 months, just drain, refill, bleed air and done.
  16. Liam howard
    56
    24
    United States
    Four Touring
    Hey Grit, what meetups you referring to?
    Raytheeagle likes this.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    m.wynn and Liam howard like this.
  18. Liam howard
    56
    24
    United States
    Four Touring
    You know if anything like that happens over here on the east coast near Philadelphia?
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Not sure, but there’s little traffic for meetups outside of what we’ve got going on, except for the So Cal folks that meet up at @RightOnTime and @sfv41901 ’s shop regularly:).
    Maybe you could start a meetup(y).
  20. Rebound
    3,996
    2,645
    Portland, OR
    You need to MAKE them happen. Start inviting Prius owners to your place.
