DIY EV switch - is that possible?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Chuck., Apr 24, 2016.
  1. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Is the EV switch so non-generic you have to order it?
    If not, I was considering getting a compatible switch at Radio Shack or Fry's Electronics.
  2. Dang5941
    Dang5941 New Member
    England
    Have you tried the scap yard, and looked for a Prius with this already installed?
    If you are looking for the genuine button.
    I'm not sure about the US, but we generally have them installed as standard.
  3. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    It was never included on Prii in the US, so unless you have a source from Europe, you won't find a stock button here in the states. There is the Coastal kit which works turns the cancel button on your cruise control into an EV mode button: Electric Only Mode or you can use a push button and install your own.
  4. josh5968
    josh5968 New Member
    alabana
    Four Touring
    I just watched a video on youtube on how to it uses your cruise switch and it looked easy to do the vid was about 15m long
  5. Prius Pete
    Prius Pete Active Member
    183
    178
    Toronto
    I did it using a generic momentary SPST push-button. I found the instructions on PriusChat. Once I found the connector with the missing pin, I just jammed a wire in. Works fine but I don't use it much.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    Chuck, you can use any generic momentary switch.
    valde3 likes this.
