DIY HID not to
Discussion in 'Prius v Accessories and Modifications' started by sean v4, Apr 2, 2015.
  1. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    Hi
    I just recently bought H11 HID from XD with the Phillips 4300k bulb an extra $45 for them to install on my Prius v4. I was very careful with them so I thought. I did the driver side fairly easy 10 minutes with mounting the ballast. But the passenger side took me 40 minutes and broke the tab on the bulb! It took longer because you want to remove the coolant tank, you can do it with not removing coolant but tight spaces. Anyhow just wanted to give a heads up to anyone who got the same kit the bulb replacement would be 74.99msrp EACH.
    There are lots of good review about this bulb that why I went with it according to toyotanation forum.
    Long story short I damaged mine :(. But luckily still work for the most part. Don't know how long that's all.
    Here the damage bulb and the result.
  2. asukadc
    asukadc New Member
    2015 Prius v wagon
    I've 55watt hid in the car right nwo( 2015 v) gonna switch them out to get the LED and see how they hold up
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    If you are switching to LED bulbs and not the oem LED headlights (entire housings), then prepare to be underwhelmed.
  4. asukadc
    asukadc New Member
    2015 Prius v wagon
    can you elaborate little more?
  5. xliderider
    8,140
    3,278
    Honolulu, HI
    It's been discussed many times. The LED bulbs out now, have the LEDs (one on each side), facing sideways on a circuit board. They do not do a good job of replicating the single point light source from a halogen bulb filament or a high intensity discharge arc. Therefore, it may put out a lot of light, but the geometry will be off, and the reflector and lens in the factory projector will put out a poorly formed beam.
  6. asukadc
    asukadc New Member
    2015 Prius v wagon
    I've read into those threads, I also found one that is a "360'' with no dark sports ... well, part is already on my way to my front door.... i guess i'll have to put them on and see what's up. thanks for elaborating.
  7. sean v4
    Corona, CA
    2015 Prius v wagon
    Asukadc
    Once installed, please post pics to see how they look. I too thought about getting LEDs at first. But went with HID instead.
  8. xliderider
    8,140
    3,278
    Honolulu, HI
    Post pictures of the beam cutoff against a flat wall about 20 to 30 ft away. Also, the beam spread downroad.
  9. asukadc
    asukadc New Member
    2015 Prius v wagon
    will do, I will do a full HID first, half and Half, lastly LED
