DIY: How to remove GenII Transmission
Discussion in 'Gen 2 Prius Technical Discussion' started by Lam, Apr 18, 2013.
  1. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Not sure what he used but I use MS Paint and it works great for labeling and changing photo formats when needed.
  2. Mendel Leisk
    42,323
    Here's a pdf of @Lam 's first post:
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks a lot Sir!
  4. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    Okay thank you LAM OP OT....
    This was a huge undertaking for one or two person team...so great work
    I have been considering this huge undertaking however have following concerns challenge:::
    concerns... challenge
    Never ever done anything like this
    Time to perform looks like could go for 26 plus single person working hours …. if all goes well
    Suitable replacement unit
    Dealer new cost 3000-4000 dollars part only
    Used range cost 300 -700 dollars part only
    New seals cost 20 dollars
    New fluid replacement cost
    access or purchase of transmission jack and engine host
    I am fairly confident that my transaxle final drive is shot. I am able to drive vehicle however the current noise generated by doing so is painful and sad to tolerate with high confidence of low future reliability of vehicle.
    One note watched LG YouTube channel on detection of final drive issue.
    #24 NortTexSalv04Prius, Nov 7, 2018
  5. zeron1982
    zeron1982 Junior Member
    Hi can anyone help ,
    I replaced a transmission and now the car engine doesn't start and the display doesn't turn off I get a message and screen says something with the parking brake ,
    Is a prius 2007 , I have to unplug the 12v battery to turn off radio display and the lights on dashboard once I plug it back in the same lights come back I get code p3102 the car was running good but because it was burning too much engine oil i decided to replace engine i got a good deal transmission and engine so I got both the problem is on the transmission.
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Check the connector for parking pawl motor. Are you sure there wasn’t problem with the “new” transmission? 12V battery good and charged? Connections at 12V battery good? What did you read the codes with? Read the codes with Techstream and see if there are other fault codes and what sub code you have on P3102?
    Here’s the chart for P3102: https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/3102524.pdf
    SFO and Raytheeagle like this.
  7. zeron1982
    I had 581 sub code and yes the transmission wasn't good I replaced it again and now the problem is fixed , thank you for the ideas.
    SFO, valde3 and Raytheeagle like this.
  8. scargi01
    scargi01 Active Member
    785
    58
    Missouri
    I have seen the connector for the parking pawl issue myself. I was having problems where the transmission would sometimes work and other times not. I took it in to the dealer, expecting to get a diagnoses requiring a $3500 repair. I picked it up and they said "No charge, the connector was loose. We pushed it back together and there is no problem now" . I have no idea how it got loose as it had been a while since I had the car worked on. I guess it wasn't pushed in all the way at some point and it slowly worked itself apart.
    valde3 likes this.
  9. Mendel Leisk
    42,323
    A very fair dealership.
  10. Jason Anderson
    Jason Anderson Junior Member
    Harrisonburg, VA
    Hey everyone! This thread really helped my dad and I out as we just finished putting in another transmission into my 2005 Prius. I took the directions from the thread and copied and pasted them and took the time to go to Photobucket and download each image separately and put it all in a document to help my dad do the work. I wanted to attach it here in case it helped anyone in the future. Good luck!
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Nice pictures dude!
  12. bisco
    52,820
    great write up!(y)
  13. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I am currently in the middle of this job to replace a damper and am at the driver side axle removal part and boy oh boy did I struggle to get that out. At least 1 hour 20 mins as i could not pry it out of the transmission and even worse from the hub, it was stuck and had to hammer the heck out of it to make it come out, to the point where the axle was eventually damaged on the threads due to the intense hammering (even with the nut installed), I’ll have to replace it now.
    Well after this, its on to the subframe removal I guess and i can already see some of the bolts with surface rust (this was originally from Missouri). Wish me luck!
  14. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I just removed my trans due to a grinding noise and a P0A90 code. I could have sworn the damper was damaged as it sounded just like others have mentioned (loud, swirling, grinding). I do have a question though @Lam or anyone who can answer this.
    I do not see the damper damaged and have not removed it yet as read in the DIY about the possible difficulty in re-torquing at the 90 degrees. However, I am certain I will need to remove it to see if perhaps the damage is behind the “clutch like” plate. Anything you guys recommend for me to look at or check before I install the replacement? I am just confused now where the grinding noise was coming from.
  15. ChapmanF
    19,003
  16. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Thanks @Lam for this great workup post, successfully replaced my transaxle using some of your info.
