[DIY] ICE & Inverter Coolant Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mindfk, Oct 12, 2015.
  1. Nouman
    Nouman New Member
    UK
    ----UK----
    I have prius 2014 with no bleeder valve and after thermostat change I don’t have heat on driver side. Not sure if there are airlocks causing this or there might be blockage in heater core. Before that it was all working fine just engine was heating up. Which is now resolved.
    I tried the followings.
    1. Lifting expansion tank.
    2. Tried vacuum tool
    Now bought a second hand bleeder valve to fit it from older model.
