DIY JDM style side mirrors combo lights (Signal+Parking+Courtesy lights)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CivicSky, Feb 23, 2011.
  1. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I installed the speed lock by pass and I learnt that the location or position of the pin on the connector is the same but the color is different. I did not take a look at the color of the turn/parking lights when they installed the mirror but earlier today while I was planning to install the DRL led, I opened the hood and the fuse cover and saw the label indicating the turn/parking lights. I looked behind the headlight unit to locate the power for the DRL and decided to get that from a tiny light on the top that always comes on when the power is on. It is pale green and its negative is white/black. Next I looked down behind the turning light and saw the yellow wire. Hope this help.
  2. khoakhoa
    khoakhoa Junior Member
    96
    28
    san diego
    Did you find someone or install them yourself? I am also looking, though may resort to DIY
  3. GaR619
    GaR619 Junior Member
    san diego
    Not yet, But I ordered mine this morning.. so Im looking now.. let me know if you find a place.
  4. zebelkhan
    zebelkhan Member in good standing
    165
    38
    Morgan Hill, CA
    Just got my classic silver painted mirror covers in the mail. The paint looks good but the color is not a perfect match. It has a hint of blue to it but not enough to be very obvious so I am ok.
    Will be installing this weekend so wish me luck!
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ luck
  6. zebelkhan
    165
    38
    Morgan Hill, CA
    Thanks to the knowledge gained from CivicSky, 32Kcolors, spiderman, and a host of other contributors on this thread my mirrors are installed and functioning great! Took me a lot longer than others to install but I am very happy with the end result. I tapped into the blue wire at A-pillar. While I had the pillar cover off I also routed my GPS charging cable to that corner so that too now has a permanent home!
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ nice,,, congratulations. It was definitely an advanced mod.
  8. jrlnc
    jrlnc Junior Member
    56
    Piedmont, NC
    Ordered mine from eBay too...
    It should be here this week.
    I hope I got an equivalent model:
    PRIUS 2010-2011 LED mirror cover turn light lamp WHITE -- color painted | eBay
    I'm not into taking apart the dash and cutting wires so I am having my friend who works for a Porsche/Ferrari dealership do it for me. He's also trained on Toyotas and Acuras.
    I put my new LED tails on Saturday and they look beautiful. I couldn't stand the rest of the non-LEDs on the exterior so I ordered a full kit for the license plate and parking lights.
  9. zebelkhan
    165
    38
    Morgan Hill, CA
    Indeed it was.
    Forgot to mention that if you tap into the blue wire on the A-pillar you will need to remember to turn the black clip (which you turned 90 degrees for cover to come off) back 90 degrees when you reinstall the cover. Otherwise that thing can blow in your face if airbag ever goes off.
  10. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    This doesn't break any California driving laws does it?
  11. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    No.
  12. Jae-DM
    Jae-DM Junior Member
    Anybody in sunny San Diego want to install these for me for a fee?
  13. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    If you're in San Diego, just take a nice road trip to Tommy. He does everything under the dash.
  14. OWG
    OWG Junior Member
    86
    16
    Barrie, Canada
    Ordered a set from Nigel. A little nervous about the install, but gonna give it a go! Will try to document as I proceed for other V owners out there.
  15. zebelkhan
    165
    38
    Morgan Hill, CA
    Don't be. Just read this whole thread carefully as information is a bit spread out, and then take your time and don't rush it.
  16. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    It's just a shame that the different versions/models/packages of Prii all have different wiring (within the same Generation span). I am terrified to begin mine, because the members with a Prius V have different wiring in different locations than someone with a 2 or 3, so their write-ups don't let someone with a II or III model see which wire they're supposed to be looking for, or where exactly it's located... Then some go thru 8 blue wires and still don't find the right blue one... I'd also like to do the SKS mod to add additional doors and the hatch to the touch-open-smartkey thing, but it looks even more potentially
    terrifying! lol
    If we had a good write-up/demo for the installation for each model, then it would be helpful to have a 'sticky thread' for JUST the II model and JUST the III model, etc., for this whole mirror installation thing, since the wiring seems to be different across the different packages. Going through 70 pages, trying to discern where the blue wire might be on a Model II or Model III, it is totally confusing and overwhelming to the normal driver whose electrical know-how and mod skills are a 1 on a scale of 1-10! lol! The thought of just doing the hit-and-miss thing for a wire is scary. Of course, I realize I'm just asking for the impossible, but it doesn't hurt to dream.....
  17. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    my turn signals from mitaacessories finally arrived today. Gonna attempt to install them this weekend.
    Really nervous about yet, but yet really excited, haha
    wish me luck guys :)
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  19. ImeanGreen
    547
    73
    Somewhere out there
    Make sure you start early and take your time. You should be OK. There's always members around here to help out. Just post your questions. ;)
  20. PatrickN
    PatrickN Junior Member
    MA
    After reading all 70 pages of this thread, I just purchased my set from mitaccessories. Any news on a similar product coming to the PriusChat Store? It seems like there's a lot of interest and I would have preferred purchasing my set from here.
    Anyways, in about a month I'll be searching for that elusive blue wire!
