DIY JDM style side mirrors combo lights (Signal+Parking+Courtesy lights)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CivicSky, Feb 23, 2011.
  1. Steve Robinson
    Steve Robinson Junior Member
    36
    44
    Mississauga, ON, Canada
    KP technologies has a small module (KP Technologies). It is simply a variable timer that tilts the mirror down when the car is put in reverse (for a time set by a variable resistor on the module) and then tilts the mirror back up for the same time (with a tweaker setting to make sure it returns to the same place). You have to set this manually once, and you may need to set it again after some repeated tilting (although I've been using if for a week and it still aligns perfectly). This won't work well if you have a multi-driver car. If you are interested, I can start a new thread on the weekend and give some directions, wiring diagrams and an "action" video. The one weakness I found is not the fault of the module. I set my mirrors fairly wide (cannot see the side of the car when driving) and Toyota (and a lot of others) don't give you enough downward tilt at the extreme outward tilt I use. Still, it is not bad - I can certainly see the curb better on that side.
  2. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    that would be great :)
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I thought that maybe I'd experiment on my Jaguar. If you tilt the mirror down in reverse, it puts it back up to memory position when you put it in drive. But then I thought this module would drive the motor crazy. Why it just doesn't go down in the first place, who knows.
    Maybe when I get some time, I'll rip into the Prius and try this module. It's only $60.
    Thanks!
  4. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Can you tell me where you got your lights and how much they cost? Also, where is Tommy located and what did he charge to install?
  5. zebelkhan
    zebelkhan Member in good standing
    165
    38
    Morgan Hill, CA
    Deleted - Double post!
  6. juejaimon
    juejaimon Junior Member
    32
    16
    I received my set today and spent the last 1.5 hours reading all the posts... an hour ago, I said to myself I'm not going anywhere near the A pillar where the air bags reside to tap the blue wire... after reading more and more and more... i'm looking to go the A pillar route now. For people who spent hours on their backs looking for this elusive wire, i give you props. :)
    What is the safest way to perform the A-Pillar tap?
  7. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Has anyone figure out the color or location of the dome light wire in the foot panel?
    arek likes this.
  8. arek
    arek Junior Member
    97
    Any response to this?
  9. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Try post #169 for courtesy light in foot panel. I think that is what you mean by dome light??
  10. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    yes the dome light. thanks for the info. I'll try that.
  11. lensovet
    2,615
    496
    Burlington, NJ
    guys, did you ever figure this out? the first post on this thread still has the dome light tap method, was anyone ever able to find the wire to tap closer to the mirror?
    also, it looks like Sigma now sells a complete kit (2 painted covers+lights) for $275.
    what was the OP's kit? i'd love to get the puddle lights going, i think it's really cool.
    thanks all
  12. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    got mine from ebay for $154 painted including shipping from Taiwan. Delivery takes about 3 weeks.
  13. w202mae
    w202mae Junior Member
    59
    40
    SoCal
    Is there a link showing this item on eBay? I tried searching didn't find it, thanks
  14. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
  15. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Just had to say that I installed these today and these instructions helped ALOT!!
  16. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    I'm not sure if it's doable connecting it from the foot lighting in the higher trim levels. I had the package 2 and tap the ground wire from the A pillar - much easier than the one behind the ECU.
  17. bzyrice
    805
    324
    West Palm
    For the puddle lights I tapped the A pillar for one wire and then tapped the foot well lighting for the other puddle light wire.
  18. arek
    arek Junior Member
    97
    Can you give us some feedback? I'm about to take the plung on this today. How many hours did it take? Any particular tips? Anything you came across that was different from the instructions...etcetc! Thanks! And which instruction was most compressive? The instructions here are for the folding mirrors so I'm wondering if the instructions were applicable...
  19. bzyrice
    805
    324
    West Palm
    I did a combination of both jdm mirror threads.. I looked at both of the 1st threads and decided which wires I would tap into from there.. Took me about 3 hours.. Because I was takin my time.. Next time it would take me about 2 hours.. Here are my tips..
    Use the a pillar for one of the puddle.. There is a vid on how to take that out somewhere.. Here is a tip on how to take it off.. Pull the pillar right above your head if you are sitting down.. Ten you will see a black clip.. Turn the clip 90 degrees and then u can pull the pillar off..
    I ran the passenger side puddle light wires to the driver side.. Wasn't too hard.. I took the glove box off and all the lower driver side panels out and used a coat hanger to pull the wires behind the radio .. For the other puddle light wire I connected it to the floor lighting.. Not sure where u can connect it if u dont have it..
    All the other wire locations in these threads are spot on! Good luck!
  20. ImeanGreen
    547
    73
    Somewhere out there
    Does Nigel's painting match the OEM BP color if I get the JDM turn singal set from him?
