DIY JDM style side mirrors combo lights (Signal+Parking+Courtesy lights)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CivicSky, Feb 23, 2011.
  1. Calvin Y.
    Calvin Y. New Member
    SoCal
    What happened to the "we are here to assist you here at PC", guess not. Only way to do it is to learn yourself and not depend everything on others! I tore part of the dash apart and found out that they were all prepped for me! It took me an entire day (day off) but have yet to get the puddle lights to work. I did see it LIGHT UP when plugging it to the dome light just for the hell of it. They would stay lit though even when the dome shut off. I didn't have hands as it was done by the touch thing. But i then later on found out that they will only light up ONLY if the car was locked, in my case it wasn't. It was simply door closed, light off and the puddles were still on. So there goes that. I think I wired the mirror's puddle light black incorrectly though. It is along with the ground (chassis/screw) which I believe was suppose to tap on the BLUE wire correct? And what about the white wires (puddle), where do I link those to? I would not want to work on the hard to reach spot dash if I don't have to though. My LEFT and RIGHT puddles, running/parking, are all together meaning someone ran them to the drivers side. The signal *RED* was the only wire I soldered to the passenger's lower corner. All works there. I spend hours reading on my bed this entire thread these pass few days! I have yet to work on the A Pillar but will do it this afternoon. Wish me luck there!
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You weren't very specific in your previous post, that's why.
    The two puddle light black wires connect to the blue wire, elusive or not, and the two puddle light white wires connect to a constant +12 V red wire (the driver's footwell light in the higher trims, etc.). Tap into the wrong blue wire and it'd be constantly on.
    Calvin Y. likes this.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I can get all the wiring done for u if needed. Shoot me a pm to discuss it in more detail.
  4. Calvin Y.
    SoCal
    Thanks guys. I am currently trying to get my puddles working. So the blacks are together and whites are together. Now just need to do the task on the a pillar
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Good luck.
    The what go to a constant 12v+
    The blk go to the "blue" wire in the A pillar
  6. Calvin Y.
    SoCal
    Alright I got them working. I tapped the red also on the pillar which I didn't want. I don't have the foot area light so I guess I didnt want to waste anymore time. After just putting everything back, I noticed my dimmer switch was not lighting up but functioning. Is it suppose to light up? I am not sure if it did light up as the others light up (fogs and solar vent). The original owner started but never completed this project and his black wires were ALL together so yesterday I thought just heck ground everything. After reading all the posts here, I knew what was the problem. Thanks guys!
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The dimmer switch doesn't light up
  8. Calvin Y.
    SoCal
    this was a great learning experience. I guess it wouldnt be that complicated if i had done it from start to finish and not just finish a half nice person mediocre incomplete job. When you guys are mentioning the the constant +12V wire, is that the one we have under the hoods fusebox? and also if it is just the positive terminal from the 12V battery. Or these two I just mentioned are the same? Just confusing for me thats all as i am slow.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    There is a constant 12v + at the lower driver kick panel. Let me see if I can find a pic
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Illhave to take 1.....doesn't look like have 1
  11. bolide
    bolide New Member
    Can someone please show me how to remove the mirror from the mirror housing? I read the first post in this thread and I cannot see the white clips when I tilted the mirror up. Thanks.
  12. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    There is no white clips. Above the picture in page 1, it clearly states this " First, to remove the mirror from the housing, you have to move the mirror angle upward. You will see 2 notches underneath the bottom of the black plastic mirror frame. Insert a small flathead screwdriver to the white plastic part(between the white plastic and mirror) and turn 90°. The mirror should come loose.
    Read more: http://priuschat.com/threads/diy-jdm-style-side-mirrors-combo-lights-signal-parking-courtesy-lights.90402/#ixzz2Umj8R3rg
    lensovet likes this.
  13. kmkremer
    kmkremer Member
    227
    30
    San Diego
    How much would you charge to install a set of the non-folding LED mirrors?
  14. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    See PM for JDM mirror steps.....
    Like
    said,
    Use a med-size flat screwdriver in between the white & black molding and turn 90-degree it should pop right out.
    bolide likes this.
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U have pm
  16. Jared Jacobs
    Jared Jacobs New Member
    Hagerstown, Maryland
    Where can I buy this from?
  17. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Most of the work separating the mirror from the mount is in breaking the adhesive used on the back of the mirror. DO NOT DISTURB/CONTAMINATE the exposed adhesive, otherwise it will not rebond at all when the mirror is replaced. The clips aren't that big of a deal.
    I'd recommend using a heat gun to heat the adhesive up a bit first on the back of the mirror and the mirror mount when re-installing the mirror. Mine never rebonded, and I ended up using auto body "dum-dum" on the backs of the mirrors to keep them in place. More or less.
  18. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    I used Permatex Clear RTV silicone Adhesive Sealant to put mine on, and it worked 'a charm!
  19. bolide
    bolide New Member
    Thanks for everyone help I installed the mirrors over the weekend. I still need to tap the wires.
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U have pm
