DIY JDM style side mirrors combo lights (Signal+Parking+Courtesy lights)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CivicSky, Feb 23, 2011.
  1. John Bergendahl
    102
    17
    gulfport,ms
    Hey cant you just wire it to the signal light in the front of the car ?
  2. OE_Plus.co
    OE_Plus.co New Member
    SF Bay Area
    technically you can,
    i just helped a fellow member install his mirrors today (ones from MIT on ebay) , for those who wants to tackle it yourself here is a quick reference you can refer to:
    Tools Used:
    10mm socket & extensions
    Philips screw driver
    plastic panel tool
    door trim panel remover
    electrical tape
    solder iron
    wire splicer
    wire crimper
    wire cutter
    digital muti meter
    remove mirror cover & door panel to take mirror out:
    Remove kick panel & Route LED wire to inside the care ( blue, red black ) to driverside kick panel ( black & white ) up towards map light
    Remove cover w/ philips screw driver (2012-2015) or 10mm bolt (2010-2011)
    i found a good ground bolt on top of the right of wire junction box ( i used a spade connect to help secure the wire to the bolt )
    remove factory insulation from 36 pin harness
    Be sure to test wire with mutimeter before taping any wire ( i personally don't like in line taps or "T-Taps" i try to avoid to use them as much as possible)
    connect blue wire ( park light signal ) to pin 18 of wire on the 36 pin harness aka park light positive brown wire (picture taken before solder, don't forget to solder wire for a secure connections)
    connect red wire ( Left turn signal ) to pin 17 of wire on the 36 pin harness aka left turn signal positive yellow wire (picture taken before solder, don't forget to solder wire for a secure connections)
    connect other red wire ( Right turn signal ) to pin 4 of wire on the 36 pin harness aka right turn signal positive green wire (picture taken before solder, don't forget to solder wire for a secure connections)
    make sure to insulate all wires after connecting
    remove map light ( i was also told that dome light wire can also be found on the A-piller) run blk/white wire up towards maplight (WARNING PLEASE PROPERLY REMOVE A-PILLAR, WIRE SHOULD NOT INTERFERE WITH SIDE AIRBAG WHEN IT DEPLOYS )
    remove harness , tap red wire to white & blue wire to black
    insulate all expose wiring and re-install everything. & you are done
    Priuschat & I are not responsible for any damages done to your car please install at your own risk. I hope this will help those who never done this mod before and is curious where all the wire are. please feel free to contact me if you have any questions or issue you run into. Keep in mind this is NOT write up, this is intended for wiring reference only. Have Fun!
    TharakaD, cproaudio and fatdawg like this.
  3. Heresjohnnee
    Heresjohnnee Junior Member
    56
    St. Louis
    Connecting the RED/BLK wires on the LED signal arrow (behind the mirror glass) to the RED/BLK wires on the JDM LED mirror lenses worked. Install now complete (except for puddle/welcome lights) and whew, it was quite a project! I was unable to remove the A pillar well enough to access the blue wire due to a metal clip holding it in place. I got it to separate from the frame but not enough to get in there with my fingers/tools. I will likely try to run the BLK/WHT wires up to the map lights. To anyone considering this, I highly recommend cross-referencing the instructions for JDM folding mirror installation for additional information on how to run the wires into the car and where connections can be made. Thanks to everyone for all the great notes here. This is a pretty satisfying mod!
  4. Heresjohnnee
    56
    St. Louis
    Can someone help troubleshoot? I just took a night drive and the mirrors work as they should. However, when I turn the headlights on, the lights behind the buttons on the flying console don't illuminate. Also, the image of the Prius/battery/engines disappears from the upper dash. Did I forget to put a plug back together?? The headlights are ON in this picture.
  5. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    U may have cut the dimmer all the way down... left side of steering wheel. I think I had did that as well or maybe it does that by default when installing
    Heresjohnnee likes this.
  6. Heresjohnnee
    56
    St. Louis
    You're right. A little wiggle of the dimmer and we're back in business!
    Accordlayingkit likes this.
  7. Accordlayingkit
    1,616
    1,747
    377
    Sweet....yea that got me too! I thought I had screwed up something big time and the car wont gonna charge anymore lol glad u got it strait!
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    On the a-pillar, did u rotate the black clip 90deg to allow the cover to move further?
  9. Heresjohnnee
    56
    St. Louis
    I completely glazed over that step. Thanks. I'll give it a try when I get back to the install.
    #1029 Heresjohnnee, Nov 9, 2014
  10. hcarddss
    hcarddss Junior Member
    Hi Guys. First, Thank for the write up. Second, I need help with the blue wire at A Pillar cover. I connect the black wire to the blue wire, the white wire to + constant 12V. the light does not lit up. When I connect the black to ground, the white wire to 12V. The light does lit up. What did I do wrong?
  11. 06d
    06d Junior Member
    Bay area
    you can also grab the blue wire if you remove your map lights. the blue wire is negative triggering so basically only when you dome lights come on it will come on, did you check the continuity of you connection? what did you use for the connection ?
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I would Double check the tap u made on the blue wire
  13. Heresjohnnee
    56
    St. Louis
    I'm struggling with the puddle lights. Any advice on how to run the wires from the a-pillar, over to the map lights, under the headliner? I tried fishing it over with a wire hanger but no dice. I could just push the wire under the lip of the headliner where it meets the windshield, but that seems like shoddy workmanship to me.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Remove the sun visor & the clip. Once this is done, the headliner will brow slightly allowing u to tuck the wire.
    iPad ?
  15. hcarddss
    Thank 06d, I finally got it working. I did reconnect the T tap and boom It lit up. :)
  16. hcarddss
    Thank sfv41901. U r right. I did reconnect the T tap and It works now. :)
    sfv41901 likes this.
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Glad it's working.
  18. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    My passenger side blinker just recently stopped working .. I need to take everything apart and check my connections. :/
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I hope it's just a connection
  20. bzyrice
    805
    324
    West Palm
    Yah we will see.. I hope to have time Friday night to take a look
