DIY Oil Change: 1st Timer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ocampod, Apr 12, 2013.
  1. ocampod
    ocampod New Member
    Chicago, Illinois
    Hi all,
    I'm new to the site and I am a new owner. of a used Prius My car is coming up on it's scheduled maintenance and I was wondering if there were any DIY guides anyone would recommend.
    Also, is it better to use ramps instead of towers with the Prius?
    Thank you and I appreciate your time and patience.
    David
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Welcome! you'll find a lot of useful people on this forum. Very helpful and informative, and here is my DIY video for you. You can use a ramp, just bend the maintenance flap and you'll be able to do your oil change.
    Irishmeatball55 and tumbleweed like this.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Your DIY videos are great, keep up the good work. :)
    No criticism but for those like me who may wish to use a torque wrench the values are: drain plug 27 ft-lbs, filter cap 18 ft-lbs. Also if you stop unscrewing the filter cap when oil first starts running out (there is a notch that lines up) the oil will drain from the filter and help prevent spillage.
    jdcollins5 likes this.
  4. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Thanks!
    And don't worry about the criticism, i know everyone has their own way of doing things. I respect that.
  5. Irishmeatball55
    Irishmeatball55 New Member
    Southeast Michigan
    Another great How-To. Thanks!
  6. NutzAboutBolts
    1,756
    1,789
    Bay Area
    thanks! :)
