DIY plugin prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Feb 1, 2008.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    There is a big flaw in the argument. "Cal Cars spent 5 years coming up with a plugin design, so why bother trying to improve it".
    It is kind of like saying. "everything worth inventing has already been invented"
    Or like saying "people smarter than you have tried and failed, so you might as well give up"
    Or how about, "I know more about the Prius than you, and I don't think it will work, so dont waste your time"
    Also, so what if someone else has done what he wanted to do. That is what hobbies are for.
    I say forge ahead with your idea. It might work, it might not, but you will have fun and learn something.
  2. Flying White Dutchman
    4,376
    313
    yhea right
    i just hope i dont damage the HV batterie:D
  3. miscrms
    miscrms Plug Envious Member
    2,079
    525
    Phoenix, AZ
    I completely agree. My plan is to do a cal-cars conversion, then start working on an improved version such that by the time my lead acid pack wears out (1-2 yrs hopefully) I am ready to upgrade. I figure I will learn a lot from doing the conversion by a recipe that is already known to work, and have the benefit of having a phev to drive the whole time I'm working on improvements. Since this is an all volunteer, open source project, my attitude is why not get the benefit of the huge amount of learning and experimentation that has already occurred, and then try to help move the collective learning forward. In no way did I intend to imply that there's no point in trying to improve upon the design. Just that there isn't much point in trying things others already have tried and proved don't work :rolleyes:
    Given that there is a high probability that this project could kill you (by electrocution, plasma fire, or unsecured 300 lbs of lead flying around the passenger compartment) or blow up very expensive parts of your primary mode of transportation I'm inclined to take a fairly conservative approach on this project. There is also a lot of concern about the negative publicity that will be generated for phevs and bevs when Bubba (no offense to anyone on the list named Bubba) puts 20 old starter batteries in the back seat then gets in a wreck and blows himself up in a ball of plasma, hydrogen gas and vaporized sulfuric acid.
    Rob
  4. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    Actually, I think there would be a lot of people who would pay to see that happen... :rolleyes:
    I also asked about losses in this proposed system. I can't read German, but I don't see the numbers there that he's wanting to use (namely 230vac to 230vdc conversion), nor am I 100% sure that's even possible.
    But I am only an electronics mechanic, so what am I supposed to know about engineering?
  5. ryanschram
    ryanschram New Member
  6. Flying White Dutchman
    4,376
    313
    edit : can be deleted
  7. Flying White Dutchman
    4,376
    313
    the prius HV battery provides 1,3Kwh
    so thats 1300 / 201,6 volts = 6,448 Ah
    when your going to use a 12 volt battery
    then
    1300 / 12 = 108 Ah
    So you need a 12 volt 108 Ah battery to have the same electric mode range like the prius HV battery
    BUT....
    you lose 10% converting from 12volt DC to 201 AC
    and 10% from 201 AC to 201 DC
    so 20 % losess
    so you need a 108 * 1,2 = 130 Ah 12volt battery to compensate for that.
    this week i got my service for the prius and next week some new tire's
    so i think next mont when paycheck is in i am going to buy some stuff
    and if i keep the state of charge the same use like the prius i only dubble the range ev mode!
    and i want to have more than that so i am thinking about useing a bit more.
  8. miscrms
    2,079
    525
    Phoenix, AZ
    Keep in mind its probably more like 2x that, or 260Ah due to Peukert Effect of lead battery.
    Peukert's law - Wikipedia, the free encyclopedia
    Also, again if you don't get above 242V, the HV battery controller won't let you use any of the extra battery " The 2004 - 2006 Prius begins to Drift at approximately 242v."
    State Of Charge Drift - EAA-PHEV
    IMHO, you are going through a lot of trouble to go from ~1 mile to ~2 miles of EV range. But whatever floats your boat I guess :)
    Rob
  9. miscrms
    2,079
    525
    Phoenix, AZ
    Most of them on the payroll of GM or Texaco no doubt :eek:
    Rob
  10. Flying White Dutchman
    4,376
    313
    firts : i dont want to charge the HV battery but leave it as is.
    when the inveter from 201volts DC makes 500 volts ac for the elec motor i inject 2xx volts into the HV lines and so it wil be used not for charging the HV battery but for powering the elec motor.
    and i am not giving power to the battery controller but behind the battery controller sensor so it wil go to the HV battery IF i want it to recharge!
    thats my idear
  11. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    you really need to make a "smart charger" able to sense when floating voltage goes above the standard, you wouldnt want to blow up the battery. I believe julian edgar did from autospeed.au.
    i have a charger all it needs is a controller to keep it at 200 volts or 273 for old prius
  12. miscrms
    2,079
    525
    Phoenix, AZ
    As a general strategy this is probably good, but there are going to be some challenges:
    1) The main HV controller monitors both current in/out of the battery and current in/out of the motors. If they are not exactly equal the controller throws an error code and disables the entire hybrid system. This is done to protect against a short circuit in the system, basically its like a GFI outlet.
    2) In order for the HV controller to decide to use more electric drive, the battery controller needs to be telling it the SOC is ~74%. If its lower than that, the car will just use the normal ratio of gas/electric and you really won't get much of any improvement in mpg. If its much higher than that, the car will start running the engine more to run the battery down and mpg will get worse.
    3) If you force EV mode (to get around problem 2), current draw will probably be in the ~100A kind of range. At 2kW, you will be sourcing <10A, so you will extend EV range by <10% over stock. This is because the OEM battery will still be sourcing 90+ amps, and the battery controller will drop SOC based on amps*time even if the voltage is being propped up by the extra battery (which I'm not sure it would be). If your converter acts as a constant current source limited to 10A, it will allow the voltage to fall with the oem battery. If it acts as a constant voltage source, it will quickly need >10A to keep its voltage up. This will cause the converter to overload and either shut down or burn out. You might get around this with a carefully sized current limiting resistor, but then you are losing efficiency heating the resistor.
    Rob
  13. Flying White Dutchman
    4,376
    313
    problem 1: if i connect it behind the sensor? so the power going into the battery is not masured the controller only notice that the drop in voltage wil be slower then normal but i dont think that wil be a problem for the controller.
    problem 2:firts i want to make a longer home-work-home where i dont get past the EV mode speed limit..
    so drifting etc to make the elec motor spin more at higher speed is not my firts concern.
    problem 3: 120a is for max accelarating on elec motor only and cruising is more like 30 amps.. if i am correct.
  14. Flying White Dutchman
    4,376
    313
    when i use a converter for providing elec power to the system i set it to make 240 volts... so it wil not go past the floating voltage
    and i only put externer converter power on the HV battery when the prius is using the battery for driving its elec motors. so then it wil drop anyway and never overcharge the battery
  15. statultra
    798
    31
    Edison,NJ
    2001 Prius
    be very careful use a low amp charging rate or you risk overheating the battery
  16. Flying White Dutchman
    4,376
    313
    o yes
    the prius battery is aircooled.
    but is this for charging or because the battery wil fast deplete a lot of amp when discharing.?
    i only going to put power on the HV lines when the prius is operational and so the prius temp sensor is going to make sure the battery is cooled
  17. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    This is just my personal opinion...
    I don't know how much you know about PbA battery chemical, NiMH battery chemical, electric/electronics circuit and others...
    However, my bet is you'll need more than three years and more than US$5k to finish your project, and a good car manufacturer, like Toyota, will introduce a plug-in hybrid by then with less than US$5k premium. :)
    Ken@Japan
  18. Flying White Dutchman
    4,376
    313
    and in after those 3 years my prius is 5 years old and i have to pay more then 10K dollars to buy the new plugin prius...
  19. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    Looking forward to hearing a good news of you in three years.
    Ken@Japan
  20. Flying White Dutchman
    4,376
    313
    :D i bet.
    good news that i am selling my 2005 prius and buying the plugin one:D
    haha
