DIY plugin prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Feb 1, 2008.
  1. Flying White Dutchman
    4,376
    313
    OK just a small update! and bump
    back in 2008 and 2009 i drove around with the BMS+ and 2 added OEM packs
    i removed those in 2009 because on long trips it would mean a lower mpg because of the added weight and in short trips i used the bike-cycle.
    now its 2012 already and after more then 2 years without a plugin i am going to build one again.!
    this time with A123 20Ah Nano-lifepo4 cells and contactor based
    i stil have that stuff from 2008 that i never used and i am building a battery case now
    balancing will be top balance using bleeding boards and a charger TC 1500 with current control
    monitoring and relay control i use 9 cellllogs to measure the 72 cells i am going to use
    and trip a relay when a over-voltage ( charger off or maybe low current mode ) or under-voltage ( beep ) occurs
    back in 2008 people where thinking i would never get it done
    and i did go for a BMS+
    no 2012 i am going to build the contactor based system stil using the BMS+ and canview
    there is a new BMS+ the BMS2 where you dont need to have canview what would safe in price of the total system.
    i am not really updating this topic because its al going down here ;-)
    http://priuschat.com/forums/prius-p...laning-canview-bms-conversion-lithium-44.html
