DIY Rear Brake Calipers
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rickinohio, Oct 21, 2023.
  1. Rickinohio
    Rickinohio Junior Member
    ohio
    I
    2014 Gen III Prius Model 2
    Maybe I missed it in my search here, but I couldn’t find a “Start to Finish” procedure for replacing a rear brake caliper(s). I’ve seen a few folks mentioning they’d replaced them without any details as to how they actually did it; the discussions seemed to focus on the bleeding procedure.
    I’m about to do mine and below is what I have in mind. I’d appreciate any constructive criticism, cautions, tips, tricks, etc. regarding my proposed method. I’m leaving out some details like jacking up the car, removing wheels, lubing various parts, etc. I’ll start with the passenger’s side rear caliper and then repeat these steps when doing the driver’s side rear caliper.
    1. Disconnect the battery. My thought is that now the rear brake booster pump (not sure what the official name is) won’t activate when I disconnect the hydraulic hose later or set any error codes when doing this (IS THIS TRUE?).
    2. Loosen the “banjo bolt” while the caliper is in place and tighten it just enough so it doesn’t leak. This is so I can quickly transfer the hose to the new caliper when it is ready.
    3. Remove the brake cable, again while the caliper is in place.
    4. Install new pads & hardware on new caliper. Prefill the new caliper with brake fluid and make sure the bleeder screw is able to be loosened when bleeding.
    5. Remove the old caliper from its mounting and hang it from something so the hose can be transferred to the new caliper when it is in place.
    6. Remove old rotor and install new rotor.
    7. Install new caliper.
    8. Transfer hydraulic hose quickly to new caliper to minimize fluid loss. I don’t like the idea of pinching brake hoses and think that there will be minimal fluid loss and any air introduced will come out in the bleeding procedure.
    9. Connect brake cable.
    10. Connect battery.
    11. Bleed this brake following Nutzaboutbolts’ Video 18 (nice video!)
  2. Tombukt2
    Tombukt2 Senior Member
    13,878
    2,521
    Durham NC
    If you do it right you won't really have to even bleed You can fill the caliper with a syringe the new caliper so that it's full completely squeezed so when you move your hoes and banjo fitting over to the new caliper and hand tighten it or whatever all you'll do is crack the little zerk fitting and watched one or two bubbles blip blip close it up and that's it I bet you won't even do anything else I didn't on mine and I've changed both rear calipers and put on slotted dimpled rotors basically just like you're describing in your text and didn't bleed a thing.
  3. ChapmanF
    19,060
    make sure the banjo is in tune, and don't let them distract you from putting the brakes back together.
    King_V and Mr. F like this.
  4. Siward
    Siward Active Member
    314
    128
    Toronto
    I once thought of replacing my rear caliper myself, so I know there are one and a half videos online:
    (shows how to remove rear caliper, but he does a shortcut cut which is not advised)
    (shows how to remove parking brake cable without cutting it)
  5. Siward
    314
    128
    Toronto
    duplicate post [deleted]
