DIY sound deadening continued...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by M One, Oct 10, 2020.
  1. M One
    M One Member
    63
    109
    Kuala Lumpur, Malaysia
    DIY sound deadening weekend project continued...
    The logic is every extra bit of material should reduce vibration and/ or reduce external sounds.
    NOT pro, not even semi pro. So appreciate understand that this is a true DIY project.
    Also NO scientific measurements taken, cos I believe enjoyment cannot be measured scientifically. :)
    What I did: as advised by many internet gurus, cover some percentage of area with sound deadening material, then top up with cotton sheet to help absorb sounds.
    Result: as expected, a little quieter than before.
    Next step: the floorboards. Maybe next week. 247402229.jpeg 362915111.jpeg 719628822.jpeg 1957245244.jpeg 425728221.jpeg 1826745520.jpeg 1850464967.jpeg 1263977685.jpeg 1129335755.jpeg
    bisco, BrianStranded and Steph1972 like this.
  2. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    Any update on this @M One ?
  3. M One
    M One Member
    63
    109
    sorry for not updating.
    I did remove the seats and dis the same sound deadening on the floor (as much as I could without removing carpet out of car).
    I can say the car definitely sounds quieter and the stereo sounds much better. Not sure on which part made the most difference. I guess they all worked a little bit.
    Meanwhile, added a used BOSE spare wheel subwoofer. That really helped the sound and I am sure the sound deadening helped to reduce the resonance which would otherwise be quite bad in car like the Prius
    52,876
    inside the doors is supposed to be a big one, and wheel wells iirc
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    sounds like you did a before and after comparison then?
  6. M One
    M One Member
    63
    109
    Did that right at the start
  7. M One
    M One Member
    63
    109
    Not a scientific one. Just what I felt personally and from friends travelling in car.
  8. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    411
    2013 Prius Plug-in
  9. kungfuaddict
    kungfuaddict Junior Member
    Tampa, FL
    I'm interested in installing on my ProHow much weight do you think this added to your Prius? Did you notice any hit on MPG?
  10. black_jmyntrn
    1,729
    411
    2013 Prius Plug-in
    maybe 10ls if that, no hit to mpg
    kungfuaddict likes this.
  11. kungfuaddict
    Tampa, FL
    What is the white 3M material used for this mod?
  12. tony_2018
    tony_2018 Member
    227
    68
    3m cotton car mat I believe.
  13. kungfuaddict
    Tampa, FL
    Awesome - thanks! Slowly installing this in mine. Completed the rear, rear seat and driver's side door.
