DIY: Spring Install
Discussion in 'Gen 3 Prius Accessories and Modifications' started by andino, Jul 12, 2010.
  1. Jim Shannon
    Jim Shannon Junior Member
    78
    34
    Janesville, Wisconsin
    Yeah....logical....
  2. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    What's the dealio everyone?
    I am planning to install the Coilovers I ordered myself.
    Does anyone have the Torque specs for the various bolts we have to screw back on? I just want to make sure I'm applying the proper pressure.
    Thanks!
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I guess you'll have to review all 7 pages to find it! lol.. It's here somewhere.. sorry but you'll have to do a little work.
    If you've done a suspension work before, this is very straightforward. The only bolt that required attention was the massive front strut bolts. I recall something like 250ft lbs. I just used a huge cheater bar.
    Ramtart likes this.
  4. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    Page 3 has a couple specs but not sure if that's what you need
    Ramtart likes this.
  5. Accordlayingkit
    1,618
    1,748
    377
    Page 6-8 has some Torque specs for ya
    http://cdn.shopify.com/s/files/1/0176/5842/files/PTR07-47100.pdf?2068
    Ramtart likes this.
  6. Chris S
    Chris S Active Member
    323
    111
    Gilbert, AZ
    I found from the forum and used these torque specs. It's been awhile but I think I found them listed on a different thread after a search. Still have them and tips for me on a phone note.....
    Posted same time as Accordlayingkit.... Awesome info there.
  7. Ramtart
    432
    797
    San Jose, CA
    You guys rock, Sorry for being an a$$clown and asking for all the specs. I'm at work and I actually found the same link @Accordlayingkit found too. Thanks also to @Sfcyclist and @Chris S !
    Accordlayingkit likes this.
  8. Sfcyclist
    1,621
    376
    SF, CA
    Don't follow my 250ft lbs! Good luck getting it to 177ft lbs though!
    Ramtart likes this.
  9. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    FYI the top strut mount is not 65 ft/lb
    Because when I torque one of the studs on the strut mount, it stretched and broke off. Now I have to buy a new $90 strut mount. :(boo
  10. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    ^^ happened to me once too.. And I've swapped out the suspension about 8 times now.. Now I just go to 40lbs
  11. Ramtart
    432
    797
    San Jose, CA
    Thanks bud for the advice. So 40lbs/ft torque for the top strut mount bolts and nothing higher and it should be fine yes? Thanks!
  12. Ramtart
    432
    797
    San Jose, CA
    Anyone do this without a torque wrench?
  13. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Here are the torque requirements that came with my TRD Springs.:sneaky:
    Use at your own risk.;)
    (y)
    HelloHybrid and Ramtart like this.
  14. trip1027
    trip1027 Member
    106
    27
    wyoming
    This looks way easier then when I did it on my 2012 ram 1500 very good instructions
    SM-N920V ?
  15. Randall71
    Randall71 Junior Member
    Indiana
    I'm hav
    I'm having trouble finding a mechanic willing to install me tein springs. Any suggestions?
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Any mechanic that is knowledgeable in replacing struts/shocks should be able to do this job. Only takes about 2hrs of labor for the 12-15 gen3 prii.
    iPhone ?
  17. ejceles
    ejceles Junior Member
    okc, ok
    Thanks for this tutorial. It was spot on. It took me right at 3 hours total (1 for the rear and 2 for the front) to install my TRD springs and I love the drop. I also put on some Scion FRS wheels and lower chrome molding IMG_20180718_102157.jpg IMG_20180717_182625.jpg IMG_20180717_173604.jpg
  18. Undertheradar
    Undertheradar Junior Member
    Long Beach, CA
    Bumping this old thread to say thanks for the awesome guide. Used it to install some Pro-Kits on our new to us 2011. Didn’t need to use the spring compressor, just wrapped the whole thing in a towel, put it against a brick wall, and undid the top bolt. Popped apart with very little excitement.
    RMB likes this.
  19. Radiospank
    Radiospank Member
    169
    82
    well, finally installed some springs lol, it took me longer because i forgot some things and did it in the wrong order, but to be fair this is my first suspension install.. Looking back it would be super easy to do again now knowing what to expect. I read somewhere someone pays 150 for install? thats awfully cheap given the cowl removal, I am expert at removing that thing now and can't imagine someone would wanna do that for 150. 5F4DAF36-EEE1-4705-A7CB-E3FE5782AFB9.jpeg
    #139 Radiospank, Jun 18, 2021
    ASRDogman likes this.
  20. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    It's usually easier the 2nd time around, because you've gained experience!
    And you won't forget your mistakes! (y)
    Radiospank likes this.
