DIY Transmission replacement on a 2002?
Discussion in 'Generation 1 Prius Discussion' started by AaronA, Jun 24, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    The floor on these cars is about $4500 right now. The junk value on these actually is pretty high too. The primary issue with the backyard swap without dropping the motor too is getting the trans off and on the motor. It has been done on Gen II, but I don't know about Gen I.
    And, of course, P3120 has a dozen different subcodes, but generally point towards the system main relay, wiring harness, or the transaxle itself.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Good point on Gen I VS GenII swap, the thread I mentioned is a Gen II.
  3. AaronA
    AaronA Junior Member
    55
    Boston
    Is there that much difference between them mechanically? Is the issue separating the engine and tranny or having enough room to do it in the engine compartment?
  4. andyprius
    2,212
    188
    AaronA: Did you read that sticky on transaxle failure?????
  5. AaronA
    55
    Boston
    I did. It looks do-able, but the question is if the body changes between gen 1 and 2 allow for the tranny to be removed separately, as Dailyphotofix did, or if the gen 1 needs to have the engine and tranny removed together.
    My friend is now unsure if he wants to sell the car, so I'll find out next week what the deal is.
    If I do get the car, my plan is to change the tranny fluid, check the 12v battery, then keep driving it until it dies. At that point, the season will probably decide if I do it myself or pay someone. When I was 21, I didn't mind working on the car in the snow and sub-zero weather, but at 42, I'll let someone else do it in the winter. :)
    When I was briefly looking through the service records, I noticed that he had accidentally added oil to the inverter cooling system (my friend is NOT mechanically inclined). The toyota dealer flushed out the system, but could this code be a residual from that mistake?
    Thanks again for all the help with this!
  6. andyprius
    2,212
    188
    Sounds like a good plan, I think you are right on the requirement to remove the engine and the tranny together. There was just a post on "489,000 miles, a mechanic in Arizona that had worked on a few Prii, he may be able to answer your question. I believe the car he worked on was a Gen I, I'll look also..........OK, easy, same page as the one you are on, 9 posts below yours, good reading and you can send him a personal message on PC.
  7. ChapmanF
    19,042
    A frequent failure in the tranny seems to be the MG2 stator. If that's the culprit, Luscious Garage knows of a way to replace the stator only, tranny in the car. Still requires pulling a stator from another MG2, but could save a bunch of labor. (As far as I know, the procedure isn't openly written up anywhere ; I think the person who worked it out sells training.)
    -Chap
  8. platypus81
    platypus81 New Member
    22
    16
    sterling, va
    YES THE TRANSMISSION CAN BE REMOVED WITHOUT REMOVING THE ENGINE. Yet again i find the answer that nobody knows by tring it out. (pumping up my ego )
    Anyway. Yes, on first generation 2001 - 2003 prius, as on the second generation, the transmission can be removed and changed alone without removing the engine contrary to what the repair manuals say. I just did it today. Will post pics tomorow. The process is very similar to the second generation only notable difference that i can remeber right now is when removing the cross member one must disconect the powersteering motor and sensors before removing it cause on first generation the powersteering is on the crossmember and not on the steering shaft as it is one hte second gen prius. My guess is that, when making the first repair manual the folk at toyota ware extra cautious pretty much the same way that the prius is an overenginired car. Thats why thay said that it can only be removed together with the engine and later on when they agreed to change the repair manual for the second gen nobody bothered to change it for the first one to.
    2 people like this.
  9. theSaj
    theSaj Junior Member
    25
    Pennsylvania
    2002 Prius
    "I doubt more than a few dozen people in the entire country would be interested and able to swap out the transaxle in their driveway."
    Hopefully my friend just added to that #...*finger's crossed*
  10. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    For the record, it's not too hard to remove the Gen1 tranny without a shop lift. You do not need to remove the ICE. (and Gen2 Prius Transmissions are even EASIER to replace without a lift)
    Simplified version; Put the car on jackstands, remove wiper cowl stuff, remove inverter, remove subframe and steering rack. Support engine from top, support tranny from below. Lower engine/tranny together a few inches then separate them. Lower tranny more then pull it out drivers side wheel well. HF motorcycle jack is perfect tool for maneuvering the tranny Aluminum Motorcycle Lift - 1500 Lb. Capacity
    Before I had a real shop lift did this all the time...even made up a wooden jig to hold engine from top and raise/lower with hand winch. One nice thing about the Prius tranny, there are no Flex plate/torque converter bolts to undo. It separates from ICE like a manual tranny.
