Do all 2011 Prius have backup camera wiring?
Discussion in 'Gen 3 Prius Main Forum' started by Remix919, Sep 4, 2025.
  1. Remix919
    Remix919 New Member
    Durham, NC
    My 2011 Prius was recently in a small rear end collision and I ended up getting a tailgate from another Prius from the junkyard, the Prius I took the tailgate from has the factory backup camera on it, I was wondering if my car has the wiring for the backup camera already behind the dash if I will need to do some modifications? I was planning on installing an aftermarket android radio and a backup camera would be nice especially since it's already installed in the tailgate so I wouldn't need to run wiring all the way from front to rear.
  2. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    Do you're car have it ? Apparently not as you talk . I don't think Toyoda do that anymore they got smart some systems now are wireless cams too . Not from factory .
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    The only way to find out is to remove some of the rear panels and find a connector, if any, that mates up to the connector going to the backup camera.
    Another way is to go to the dealer and find out if the camera requires an add on wiring harness to the camera, and if the screen unit on your particular has a connector for a backup camera.
    It's up to n you to find out.
  4. ChapmanF
    19,009
    You can look in the Electrical Wiring Diagram. Toyota Service Information and Where To Find It | PriusChat
    Wires that are only present in certain variants of the wiring harness will be shown with a small asterisk and number in parentheses, like (*7) for example. Somewhere on the page there will be a legend saying something like "(*7) w/ Rear View Monitor".
    When that's the case, it usually doesn't mean that there's some extra wire harness you can buy and lay in that only adds the extra wires. It means that the whole wire harness comes in variants with and without those wires. Or, several wire harnesses may all come in such variants (say, one in the hatch to the roof, one down the pillar and along the floor, and one behind the dash).
    Of course, if you have the variants without the camera wires, it may be a lot easier to just get a roll of suitable shielded cable and some connectors and lay that in alongside. Replacing whole wire harnesses with their with-camera variants would be very tedious.
  5. Remix919
    Remix919 New Member
    Durham, NC
    I'm talking about if I have the connectors behind the dash going to the radio, I do have the camera connector in the tail gate going to the module in the headliner.
    Is there any free wiring diagram resource? I looked at that post but it goes to Toyota Europe that requires a special login?
  6. Remix919
    Remix919 New Member
    Durham, NC
    I also saw they have reverse camera wiring harness adapters for the 2012-2013 Prius but it doesn't cover the 2011 Prius for some reason, any idea why?
  7. ChapmanF
    19,009
    If you spend a little more time in that post, around where it has headings like
    • Where To Find It
      • Free Databases
      • Toyota Subscription Databases
      • Third-Party Subscription Databases
      • Printed Books
      • CD-ROM/DVD-ROM
      • Unofficial Sources
    you may find a suggestion that works for you.
    Among the Toyota subscription databases, the North American one probably covers your car more precisely than the European one, if your profile is right that you're in NC. It's true the European one has cheaper subscription options, if it's available from here.
  8. Tombukt2
    13,848
    2,515
    Durham NC
    He rt up street from me . But I've no gen3 literature at all . Look behind you're radio for the connector on my gen2 easy to see .
  9. Remix919
    Remix919 New Member
    Durham, NC
    I got the radio installed and the 2 plugs not used are these two, I'm assuming the backup camera wires must be on one of these plugs, does anyone have the pinout by chance for these? I believe they are the L50 and L84 connectors. On one website I found L50-9 and L50-10 are the +/- for "AVC-LAN communication signal, not sure if that means backup camera or something else?
    #9 Remix919, Sep 8, 2025
  10. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    If you go to your local Dealership they should be willing to pull you up the specific prints for your VIN. Hack Shacks can also very helpful.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    If yours is a trim iii or higher then it is equipped with camera wiring.
  12. Brian1954
    Brian1954 Senior Member
    2,671
    1,069
    South Central PA, USA
    I do not think this is true. I own a 2011 trim III. I added an aftermarket backup camera to my car earlier this year. The car did not have a wiring harness in the hatch for an OEM backup camera.
