Do All Gen 3 Prius W/ Moon Roof have the solar panel?
Discussion in 'Gen 3 Prius Main Forum' started by Haschwalt, Jul 24, 2019.
  1. Haschwalt
    Haschwalt Member
    110
    31
    New York
    The Toyota brochure wasn't very clear on this as it just says "Power tilt/slide moonroof with Solar Powered Ventilation System and Remote Air Conditioning System with sliding sunshade" (Source: https://cdn.dealereprocess.net/cdn/brochures/toyota/2015-prius.pdf ).
    Has anyone seen in say a 2013-2015 Prius a moon roof without the solar feature?
  2. Grit
    Grit Senior Member
    5,896
    3,960
    Wilkes Land
    Clear as daylight, powered moonroof w/solar powered vent system.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    938
    712
    Virginia, USA
    46,684
  5. Raytheeagle
    Raytheeagle Senior Member
    11,250
    15,449
    Bay Area, California
    2019 Prius Prime
    Another Morse code post on the same day:whistle:.
    Bay Stater likes this.
  6. orenji
    orenji Senior Member
    5,881
    3,482
    If it’s the OEM moonroof, then yes.
    Bay Stater and Haschwalt like this.
  7. Tideland Prius
    15,585
    All moonroof equipped cars have the solar panel.
    Mendel Leisk and Bay Stater like this.
  8. Bay Stater
    Bay Stater Senior Member
    534
    770
    Central Mass
    And the ability to vent the interior during bright day light.
    Tideland Prius likes this.
  9. JarrettOriginal
    116
    81
    North Hollywood
    Yeah, and while it does a little bit for the heat it isn't really worth it.
    I bought mine used, and it was the best deal so I got it.
    But I don't find myself using the moonroof much, it's usually too warm to leave the shade open, and the solar panel only runs that little fan.
    If it charged a little battery with a usb port for charging, especially in emergency situations, that would give it some value.
    But, ultimately, it seems to only be a marketing thing from Toyota.
    SM-N950U ?
    Ed Beaty likes this.
  10. Ed Beaty
    Ed Beaty Active Member
    334
    308
    Salt Lake City
    I have a 2010 trim V, and I agree. It's very nice, but it's basically just gilding the lily (as it were).
  11. Grit
    Grit Senior Member
    5,896
    3,960
    Wilkes Land
    One time at work I came back from lunch and all the shaded parking spots were taken so I had to park out in the sun. 4 hours later I was able to start the car but EV never came on. As I drove off, I blasted the AC. The last minute of driving EV finally came on. Got home & parked the car, saw the solar panel button disengaged. I've parked 8 hours directly under the sun many times before w/fans running, EV always did its thing. That's why that feature isn't a gimmick if you can put it to use.
    If I had the trim package 5, I wouldn't be able to use the radar cruise control & parallel park assist. My commute is all country side driving with no one in front of me majority of the time and there's no parallel parking where I commonly park at. Now that trim is a gimmick :p
    RMB likes this.
  12. Tideland Prius
    15,585
    The original intent of that solar panel was to charge the hybrid battery. They ran into some issues with some sort of interference (electromagnetic I guess).
    Maybe it's too hot to be useful where you are but it was quite useful here in Canada. It basically reduced the heat build-up inside the cabin, allowing the A/C to work more efficiently and quickly to reduce the cabin temperature. Parking next to our Gen 2, the difference is noticeable (and the Gen 2 had the beige interior, while my Gen 3 had the dark grey interior)
  13. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    I bought a used 2011 plus performance evolution with the sunroof / solar panel and I love it! I live in Gilroy and have also used the AC button on a hot day. The sunroof also comes in handy to help cool down the traction battery.
    The back seat now has a cover and my husky survives the hot days!
    Thank you Toyota!!!
  14. ASRDogman
    ASRDogman Senior Member
    4,910
    2,795
    Since you have a dog....
    You should get this filter. Got the larger filter from Toyota, and the other is a/c filter from home depot or lowes...
    I just wash it with water once a month and let it dry.
    The extra foam helps keep the fur out.
    You don't want another husky in the HV battery system! :)
  15. ASRDogman
    4,910
    2,795
    Also, I'm on my 3rd back seat cover. 1st one was really cheap and started to fall about within a month,
    and the first time I washed it.
    The 2nd one was better, it was lasting longer.
    3rd and current one, is doing much better. It was on sale from $40-50, down to $25.
    It's a little wider so it reaches the doors on the Prius. And the zippers work from top to bottom.
    The other's kept working their way down, almost useless, not quite, but close.
    The only downside so far is when I have one side open, the slider for the zipper will fall off.
    I didn't know that one had come off, and I shook out the liner, and the slider went into the yard!
    I didn't realize it because I was doing it quick because it was going to rain and I wanted to get
    the dogs in the car and get on the road. I didn't bother to zip it up.
    I found out the next day when I was on the other side of the state.
    But, I did find it when I got back!!!
    I can wipe 95% of the fur off with my hands, it's nice! A little sticks, but not like the other ones.
    I've washed it twice, but I think it's waterproof!
  16. JarrettOriginal
    116
    81
    North Hollywood
    Well, I've never had an issue with my traction battery, so maybe it does more than I think?
    SM-N950U ?
  17. Haschwalt
    Haschwalt Member
    110
    31
    New York
    is this the cabin air filter?
  18. bisco
    46,684
    it is the intake grille in the back seat for the hybrid battery cooling fan. but he is replying to someone else about dogs, not your original question
    Haschwalt likes this.
  19. ASRDogman
    4,910
    2,795
    That's for the HV Battery. The Toyota filter is "ok", but the foam ads extra protection from fur!
Loading...
