Do all Prius' have this LED issue?!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mizzaxer, Jun 19, 2011.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Not sure if you could. Those color bulbs have the glass itself colored. You could try it
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The specs are fine, but it sounds like it might be a shoddy construction because a reviewer mentioned one of the bulbs burning immediately after connection. The bulbs seem to be tinted blue in the glass to produce whiter/cool blue light. If you wanted actual blue lights, you can get blue LEDs.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The only problem I have with blue bulbs is is almost too pure in color. Normal blue runs 450–475 nm in the visual spectrum. The LED output is usually pure to the point of 2 to 3 nm in spectral width. That's quite a pure color. Most quality LED vendors will have a spec sheet to reference the color wave length of the LED's you are buying.
