Do current Primes emit the pedestrian warning sound?
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Aug 2, 2018.
  1. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Window has to be down. I only hear it when creeping along right next to a building, like when going through the McDonald's drive-thru. It is very low volume. Sounds like steam escaping.
    schja01 likes this.
  2. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Yours may not be working like my wife's Prime. The reason I noticed it was it's our second Prime. It may not be you, plus if it's too low volume, you can have the dealer turn it up to level 2 or 3. Just listen to level 2 or 3 before commit and make sure it doesn't drive you crazy being too loud. I think it is very helpful in slow speed parking lots and where people are walking around you while going very slowly.
    schja01 and bisco like this.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    At least on 2017s (and I’d expect 2018s to be the same), yes, there is a pedestrian warning sound. It’s not a beeping sound if that’s what you’re listening for. It’s more of a rush-of-wind kind of sound, or like an amplification of the motor sound. Thankfully, it’s pretty hard to hear from within the cabin, unless you have your windows down.
  4. schja01
    schja01 Senior Member
    1,863
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    Hallelujah I finally heard it while pulling into the garage. So did my wife. Part of the problem is I didn’t know what the sound sounded like. To me it sounds like a 17 year locust but infinitely quieter.
    Thanks to all who replied.
    J
  5. Prodigyplace
    12,708
    11,847
    Central Virginia
    A coworker calls my Gen 4 Prius my spaceship. :LOL:
  6. pineprius
    245
    134
    NC
    Having lived in Chicagoland a while back, I understand. A long time ago driving on the Tri-State (I294) near Ogden avenue, I thought one of my wheel bearings was failing, only to find out exiting, that it was the wonderful cicadas screaming at me. Very lovely like a horror movie.
  7. Jeff Cohen
    Jeff Cohen Junior Member
    Dallas, TX
    2003 Prius
    Mine sounds like shhhhh-oooooo-shhhhh-ooooo. The wife's Leaf makes more of an electronic chime sound which repeats.
    Prodigyplace likes this.
  8. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    At least it's not the sound this Cirtoen concept makes:
  9. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Just changed mine to Level 3 with TechStream. Can't tell a difference yet but was in a parking lot with others noises. There is an option to turn the noise on when the car is sitting still also.
  10. Diemaster
    Diemaster Active Member
    298
    263
    so. cal
    I took mine apart and shoved packing peanuts in against the speaker to silence it. I was going to unplug it but it will throw a code then.
  11. Prime Alex
    Prime Alex New Member
    29
    Manitoba, Canada
    2020 Prius Prime
    Upgrade
    I think some people are confusing the warning sound made in the cabin to alert the driver that a passenger or obstacle is present, which can be adjusted for loudness, and the sound referred to in the video that is emitted regardless of the presence of anyone and which is indeed as subtle as it is, well, not very elegant sounding.
    Have there been any reports of anyone changing this sound to something more urbane?
  12. schja01
    1,863
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    My son just purchased a 2020 Corolla Hybrid and the sound it emits is very noticeable. Sounds to me like a bad water pump bearing or slipping fan belt. Since the ICE is off the sound is not engine related. When put in reverse it’s twice as loud. Perhaps so people behind the car can hear it. Not so with the Prime.
