Do higher NO_x numbers explain Eco's much superior fuel efficiency?
Discussion in 'Gen 4 Prius Main Forum' started by Gokhan, Jan 31, 2016.
  1. Trollbait
    12,832
    Are the NOx results in the table an average of the results from the EPA spread sheet?
    EPA Tier 2 Bin 2 has a NOx threshold of 0.02g/mi for full useful life under the FTP test cycle. Non of the Prii tested exceeded that for any of the tests. The Eco gets 7.7% better fuel economy than the regular Prius.
    The 1993 Civic VX is well known to hypermilers for its lean burn mode. It is rated 13.2% better than the regular Civic in fuel economy. Its age means that it fell under Tier 1 rules with a 0.6g/mi threshold on NOx. Even then the lean mode emitted too much NOx for CARB states, and the mode was disabled for those markets. The real Insight also had a lean burn mode. It needed a NOx trap, something otherwise only used on diesels, to keep its NOx emissions low.
    Same question Bob, because your responding post is only comparing Toyota's new sensor to a heated oxygen sensor, which is pretty much the default one for all cars. The VX had a wideband oxygen sensor, which has 5 wires to a heated one's 3 or 4. The cost(>$100) to replace it can be daunting for such an old commuter car.
    Which is why I suspect this air sensor isn't new, but just new to Toyota. It is a company that didn't offer a better than 4 speed automatic transmission on their popular Corolla until last year, and the 4 speed is still on the base trim.
  2. bwilson4web
    16,552
    I took the highest MPG row for each of the three model vehicles and made the table those three rows. I didn't average anything:
    Represented Test Veh Model PRIUS Eco PRIUS PRIUS c
    1 Test Vehicle ID 16-ZV2H 16-ZV1H 12-NP2H
    2 Test Veh Displacement (L) 1.798 1.798 1.497
    3 Rated Horsepower 96 96 82
    4 Equivalent Test Weight (lbs.) 3250 3375 2750
    5 Axle Ratio 2.83 2.83 3.19
    6 THC (g/mi) 0.01172 0.01438 0.00464
    7 CO (g/mi) 0.06442 0.08763 0.04183
    8 CO2 (g/mi) 105.40951 113.86017 117.82708
    9 NOx (g/mi) 0.00295 0.00187 0.00106
    10 CH4 (g/mi) 0.00195 0.00224 0.00077
    11 N2O (g/mi) 0.00135
    12 RND_ADJ_FE 84.1 78.0 75.0
    13 Target Coef A (lbf) 17.130 18.272 17.919
    14 Target Coef B (lbf/mph) 0.28731 0.29545 0.18180
    15 Target Coef C (lbf/mph**2) 0.01386 0.01379 0.01556
    I learned about it by reading the 2016 Prius "New Car Features." I had not seen it in other Prius. As for non-Prius cars, I'll defer to your expertise.
    The only non-Prius cars I have even a passing interest are those claiming to having higher MPG over a Prius. EVs are a special case because they are so simple, they instantly become boring. An efficient car with an engine tickles my curiosity.
    #22 bwilson4web, Feb 2, 2016
    douglasjre likes this.
  3. Gokhan
    Gokhan Senior Member
    6,717
    2,672
    Paramount CA
    Translation: No car other than the Prius Eco or other Gen4 Prius with an Eco engine-control module swapped in. (y)
  4. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    plus the wideband O2 sensor and maybe the catalyst.
  5. Trollbait
    12,832
    The difference in NOx output is too low to be actual lean burn. The fuel economy would have been even better if it were, and there would be a different emission control system on the Eco.
    The Eco could be more aggressive with ignition timing, but the results might be falling within the standard deviation of the gen4's NOx emission levels.
    Once the smog ratings are posted to Fueleconomy.gov, the engine codes of the cars can be checked.
  6. Tideland2005
    Tideland2005 Member
    72
    34
    SoCal
    I wonder if the Atkinson cycle timing is different Gen 4 vs Gen 3..?
    Both engines have high, 13-to-1 static CR. And, late closing intake valve allows intake charge to bleed down to yield effective ratio around 11-to-1 on the Gen 3.
    Perhaps the supplemented EGR on the Gen 4 allows higher effective CR (with less intake bleed down)?
    And, the Eco 2 is some variant of this with still different Atkinson timing?
    Just speculating......
    #26 Tideland2005, Feb 3, 2016
  7. Trollbait
    12,832
    The question of whether there are different engine controls should be easily answered by comparing the EPA engine codes between the Eco and another Prius. They aren't posted on Fueleconomy.gov yet, but they are on the a sticker inside the hood or front edge of the engine bay.
    "The Eco could be more aggressive with ignition timing" was in error on my part. What I meant there was that the Eco might run a little to the lean side of stioch than the Prius, but it doesn't have a full lean mode like the Hondas and other earlier cars.
  8. bwilson4web
    16,552
    There are errors in 'Fueleconomy.gov' that I hope our friends at Toyota wake up and fix. For example, internal volume is off.
  9. Trollbait
    12,832
    The volume measurement for EPA classes could be a different method than what is used for marketing. What GM posted for gen1 Volt rear cargo on the Chevy site was 8 cubic feet less than what was on Fueleconomy.gov. It was likely the difference between measuring the height up to the roof and measuring it to the top of the rear seats.
    The engine codes and smog rating simply isn't up yet, and it be due to a longer review process than for fuel economy numbers.
  10. Gokhan
    6,717
    2,672
    Paramount CA
    I am sure the regular Prius is also lean-burn. Gen 4 Prius Eco is leaner-burn in comparison to regular Gen 4 Prius. There may be other things tuned differently for the Eco as well, such as ignition timing, valve timing, emissions, etc.
    Someone who has access to TIS (costs $10 a day) can look up which engine parts are different in Prius Eco. I am guessing the only difference is the ECM. You can also download the service manual, new-car-features whitepaper, etc.
  11. bwilson4web
    16,552
    I bought a month of access, $75 or $3/day, and have already done a first pass of the 'New Car Features.'
    What stood out was the fuel-air-ratio sensor that is not in the Gen-3. Unlike the oxygen sensors that are 'binary', this sensor has a linear response which means finer tuning can be done on the mixture. In effect, keeping the car on the lean-side, mixture while still meeting emissions limits.
  12. Gokhan
    6,717
    2,672
    Paramount CA
    Do you have access to the part numbers? Does it show different part numbers for ECM etc. (it would be under fuel-injection system) for the Eco and regular engines?
  13. Trollbait
    12,832
    Lean burn is a proven method for increasing fuel efficiency, and nearly every manufacturer made use of it in the past. It is actually one of diesel's 'secrets'. The majority of modern gasoline cars no longer make use of because of the large amounts of NOx it produces.
    The NOx numbers are only a little higher than the other trims, and it isn't high enough to push the car into a dirtier bin, like the gen1 Insight was compared to the gen1 Prius. There are three possible explanations for the higher results.
    1. There is no difference between the car's ECU software, and the results are actually statistically the same.
    2. The Eco runs a little more on the lean side of stoichiometric for the air fuel ratio. This alone would not explain the Eco's fuel efficiency gains over the others given that the car still falls into T2B2.
    3. It has a true lean burn mode, aka the Insight and VX. If so, it also has additional emission control equipment, like what a diesel has, in order to get the NOx down as low as it is. This will be easy to check from the EPA engine code or parts catalogue.
    I think we are starting to hit the wall in terms of high fuel efficiency with low emissions, and Toyota has had to use a wide range oxygen sensor as one of the ways to do so. It will allow finer tuning of the air:fuel ratio, and may be required to properly adjust the valves between economy and power settings. It is needed for a lean burn mode, but isn't evidence of that on its own.
    Note: Stoichiometric air: fuel ratio is 14.7:1. Honda's with lean burn could go up to 22:1.
  14. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...or better cat converter? But I am going with statistical equivalence for now, must be variations in fuel quality if they changes batch of fuel between cars, not to mention warm up state and ambient temps might add in.
  15. Trollbait
    12,832
    The Insight was able to go really lean. It had an LNT like a diesel.
  16. ccdisce
    259
    187
    Stone Mtn GA USA
    Thanks for the info on the presence of a LNT.
    In the early days I was also informed that there was a time limit on how long the ECU could run at an AF of 22 to protect the catalyst from meltdown.
    The ECUs that use switching NTK O2 sensors (in another car make that will remain un-named) can run AF ratios out to around 16 as the base AF table is provided with an -ve offset table which is then added to the base table. Usually the tables are in units of Lambda.
    NO2 can be reduced by EGR and it does deliver this benefit along with lower pumping losses resulting even higher MPG numbers but you may start to run into detonation issues which may require forged PTFE clad, ceramic top pistons instead of metal-matrix, cooling the exhaust gasses being recycled is an option up to a point. Piston cooling with oil jets were provided for in the Gen3
    Trailer-hitching could become the next limit.
    As I had the programming files for an MDE2 ECU ( for a 4.6L V8) I tested the above ( no piston change) and raised its MPG from 24.2mpg to 41.6mpg. Detonation became an issue running this tune for about 5 minutes upper limit on RPM was 1750.
  17. Trollbait
    12,832
    Lean burn engines running hot seems to be a myth. It is well known that they produce more NOx. While NOx formation requires a high temperature to start, which is present in the engine cylinders no matter the fuel ratio, the reaction itself is endothermic; it will cool down the exhaust as it occurs.
    I'm guessing the damage people saw from improperly running lean burn was actually from engine knock.
    bwilson4web likes this.
  18. Gokhan
    6,717
    2,672
    Paramount CA
    Bob, have you been able to compare the part nos. for the Prius Eco and regular Prius ECMs (under the fuel-injection category) on TIS? Are they different as we suspect?
    Thanks.
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I owned a 1994 Civic VX purchased new and gave it to my dad when it had over 210,000 miles and stayed in the family until it had well over 300,000 miles. The engine was a 1.5 VTEC-E engine and it really obtained 50 plus mpg with the 5 speed manual tranny. I understand the lean burn was when the engine was running under 2000 RPM's or so if I recall...
  20. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    So, are you suggesting that those of us who want more of the safety features than are available on the II-ECO might want to wait a bit to see if Toyota puts new tech into the other Prius models, and get even better MPG?
