Do higher NO_x numbers explain Eco's much superior fuel efficiency?
Discussion in 'Gen 4 Prius Main Forum' started by Gokhan, Jan 31, 2016.
  1. Trollbait
    12,829
    We don't even know the Eco has a lean burn engine.
  2. bwilson4web
    16,535
    First Kudos to Consumer Reports who at least honored the Nov 8, press embargo by publishing later, November 18th. But everyone has had to deal with the slow release of information. It wasn't until January that we got access to the EPA "Test Car Database" that gave us the emissions data. Then in February the New Car Features that told us about the fuel mixture sensor.
    It is impossible to identify a single change that gave a specific MPG increase. Rather the sum of the parts, the incremental changes, gives the performance improvement. But understand I am not a Consumer Reports fan as other publications and reporters have done much more with less.
  3. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Do we know what the difference in EPA fuel consumption between the Eco and the other models actually is?
    With rounded numbers of 52 and 56 mpg, the actual difference could be anywhere between 3 and 5 mpg.
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
  5. Trollbait
    12,829
    The data source used for that thread, was posted here with nothing stripped. Which makes is tougher read, but shows the Eco model emitting more NOx. But we are talking miniscule amounts to begin with, and the Eco has the same smog rating as the others.
    So the Eco numbers could be the result of trading off the emissions a little bit, for a little bit improvement of fuel economy, or the results are within range of each other to be considered statistically the same.
    But there is no actual lean burn mode proposed in the OP of the thread. It would require a different emission control system to clean up that much NOx, and frankly, the Eco MPG rating would be disappointing if lean burn was being used.
    The gen4 is up on Fueleconomy.gov now, so we can check engine codes under the environment section.
    The Eco is GTYXV01.8PC4.
    The others are GTYX01.8PC3 and GTYX01.8PC4.
    The hybrid battery is counted as part of the emission of the emission system. So the two different codes for the others is for the NiMH and Li-ion batteries. The Eco shares the code with the other Li-ion. So it has the same emission system as the others. Without extra equipment to clean up the NOx actual lean burn would produce, it couldn't make use of it and retain the same smog score.
    So the Eco does not have a lean burn mode.
  6. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    We are saying "leaner-burn" not "lean-burn." There is no such black-and-white thing as lean-burn or not lean-burn. Even the regular Prius must run on the leaner side to increase the engine efficiency. The increase in Eco's NO_x numbers over the regular Prius is about 50%. Sure, it's still a small number in absolute sense, as it's still below the PZEV/ULEV-II limits, but in relative sense, this 50% relative increase can do wonders in tuning the engine toward better fuel efficiency.
    It makes no sense for Toyota to create a separate Eco trim line by merely reducing the weight of the car by about 100 lb and putting a few more psi of air in the same tires -- no sense at all. Prius Eco is more than than that. If anyone thinks that you can increase the fuel efficiency by about 10% simply by 100 lb of weight saving in a 3,000 lb car and pumping a little bit more air in the already overinflated tires, that person has no engineering intuition.
    douglasjre and KrPtNk like this.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Thankfully, we are not reduced to intuition, we have the facts. Aerodynamics and weight reduction are Toyota's explanation, and the EPA's explanation. Feel free to try to show that 35 PSI is 'over inflated' in any sense, we will wait.
  8. Gokhan
    6,714
    2,672
    Paramount CA
    Toyota is listing the same drag coefficient in the specs for the regular and Eco trims. Weight and tire psi -- there are no significant differences there. EPA doesn't explain fuel efficiency -- it only measures it. What makes you think that Toyota would come out with any dirty (pun intended) secret of the Eco trim?
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If Toyota had a secret way to get better gas mileage on every Prius, it would use it on every Prius, they could sell more.
    Instead, Toyota carefully 'rations' weighty options, you can't get 17 inch wheels and the moon roof on the same Prius, so that they do not have to lower MPG estimates. By aggressively rationing options, the Two Eco manages to slip into a higher Estimate, no magic, no secret sauce, just careful choices. (sadly owners who, like you, think there is a 'secret', buy an Eco with the plan to put the spare tire back in, negating most of the advantage of an Eco)
    You could test this yourself in your current car, by having a loved one take out the spare tire and jack randomly while they document the odometer reading and let you do 'blind' MPG recording, never knowing when the car was lighter. (Taking out the rear windshield wiper motor and washer pump motor or changing wheel size will leave a mark, making it harder to do 'blind' recording)
    Car Bibles: Get better gas mileage - improve your mpg
    Trollbait likes this.
  10. Gokhan
    6,714
    2,672
    Paramount CA
    Not necessarily. The Eco trim makes up only about 10% of the Gen 4 Prius sales. If it has 50% more NO_x emissions, that means only 5% more emissions for the entire Gen 4 fleet. If they did the same trick on all Gen 4 Priuses, it would result in a 50% overall increase in the entire Gen 4 fleet, rather than 5%. By keeping the Eco-trim sales small, Toyota can remain discreet about it and also maintain its overall emissions goals.
    Merged
    If you really care, there is a very easy way to prove or disprove this hypothesis. Stop by at the parts department of a Toyota dealer and request to obtain the part nos. of the engine-control module (listed under the fuel system) for the Eco and regular trims. Different part nos. would prove and same part nos. would disprove it.
    #70 Gokhan, Mar 5, 2016
  11. vince22
    vince22 Active Member
    205
    249
    califorinia
    I have installed full size spare tire with my Two Eco and nothing has change in regards with Mpg and I'm also inflating all tires around 35psi for better ride.
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If it is legal for one model, it would be legal for all models.
    Now would be an insanely bad time to introduce a a foreign car that did not pass EPA standards.
    VW Faces $17B Fine for Emissions Scam | PriusChat
    Merged
    So, $500 decals?
    #72 JimboPalmer, Mar 5, 2016
  13. vince22
    205
    249
    califorinia
    Its gotta be something else more besides the weight, I bought ECo model for lithium ion battery and 3 doors smart key worth $500 imho.
    #73 vince22, Mar 5, 2016
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Whew, I was worried you bought it for the gas mileage you negated.
    Toyota does mention other gains besides weight loss: energy conserving glass, and aerodynamic improvements, they are considered minor, but Toyota thought them worthwhile.
    Of all the features I lost moving to a v Three, 3 door SKS is the one I miss most.
    #74 JimboPalmer, Mar 5, 2016
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    The EPA data base confused me because eco is in different weight class, which apparently impacts test conditions, so for me personally, I am still unclear on it.
  16. Trollbait
    12,829
    How do you know? Have you tried increasing the tire pressure and testing the difference. I see one on my car, and the higher the base MPG rating, the higher the whole number increase will be from it.
    What would be so dirty? The cars have the same smog score, and that is what most people would see, if they even cared enough to look into it.
    The only people that would care, are those that want to brag about the Prius being cleaner than other models that happen to be in the strictest emissions bin that an ICE car can achieve
    You started the thread. The burden is on you to prove your hypothesis. With the Eco and the other Li-ion models having the same engine code, they have the same equipment. If you think that is in error, then you have to find the evidence to disprove it.
    Weight class doesn't effect EPA test conditions. The car's actual weight does when determining those. Weight class has more to do with determining which models have to be tested.
    Toyota limits options on the Touring models in order to keep them in the same weight class as the 'regular' trims. This way they can use the regular MPG numbers on the Touring window stickers. Yep, this is what Ford did with the Fusion hybrid and C-max numbers. The Eco falls into a different weight class. So even if there was no difference in fuel economy, it would still need a separate EPA entry. I suspect this was the case with the Camry hybrids. The weight difference was enough between the LE and the others that Toyota had to do a separate listing, not because they chose too.
  17. Gokhan
    6,714
    2,672
    Paramount CA
    Next time I go to the parts department to buy something, I could request it. I don't think a different engine-control module necessarily results in a different engine code.
  18. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    It could be psychological. People who buy the eco naturally drive more efficient therefore the eco gets better milage.
  19. bisco
    52,856
    it has to be epa testing, or another agency. peeps buying the eco have no way of knowing if it gets better mileage than non eco.
  20. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    I never thought the Prius Eco would have higher NOx emissions than the normal Prius, because no lean burn is involved. Lean burn is why the 5-speed Honda Insight was rated ULEV instead of SULEV, like it's CVT version. Lean burn can have an air/gas mix up to 25.8 to 1 instead of the usual 14.7 to 1.
