In the interest of changing only one variable at a time, I'm going to put off the oil change for a couple of weeks. You see, following the excellent instructions I found here at PriusChat, I decided to check the cabin air filter this morning before heading off to get the oil changed at dealer number 2. I found somewhere around two cups of dog food on it, along with other scrap material! Apparently, some mouse or rodent has been busy... Unfortunately, I didn't take a picture, although I did show it off to everyone in the family I've now got a new filter (since the old one was chewed up a bit) and removed most of the dog food... some of it spilled off the filter, so I've still got to clean that out. I picked up a flexible crevice tool at a local vacuum cleaner shop... just the thing to reach into those narrow spaces, I think I'll post a review of it after I'm done getting the last of the dog food. In the meantime, I gassed up today and in the ten miles since then, I'm averaging 49MPG... easily a 10MPG increase in my book. I'll see what it all looks like when I'm done, but this just might be a silver bullet.... Points to ponder... 1. How long has that stuff been there? If it's since the check the dealership did a bit ago, that rodent's been really, really active. If it's been there since September, why didn't the dealer notice when I brought the vehicle in to get the poor MPG checked? It takes me all of 90 seconds to check it now... 2. If that's the culprit, then why the sudden dropoff in mileage back in September? I suspect the oil change added to it... the paperwork shows that they put 4 quarts in, and the dipstick shows pretty full as of this morning. I'll double check that as well... a little later on today. 3. At both oil changes, they did a multi-point courtesy check. Do they actually have a checklist, and can I get a copy? I'll have to ask them... it would be interesting to know what exactly went on. More news when I get it, but I suddenly have the feeling I could join the 50+ club here shortly...
An you've got me wondering who may have set up camp in my air filter . . . You've GOT to post pictures.
what, like 90-weight gear grease? (important) I'm so amazed to read this thread. I don't have anything to contribute, but that I've also reflected upon many recurrences of the exact same symptoms you describe. Here's what happens to me (not important, but detailed): (1) take vehicle in for scheduled maintenance (2) car gets shockingly worse gas mileage on the way out I've encountered this numerous times, and every time I start thinking about Microsoft and the term "planned obsolescence" and it just drives me nuts but there's no hard evidence of anything other than a suspicion. Moreover, I wouldn't -actually- suspect planned obsolescence (nobody would want their own brand vehicle (or any vehicle they service) to leave the shop with noticeably worse performance, ruling out all but the least deliberate of motive. (important again) I never could figure out what manner of accidental mis-calibration could cause such a dramatic drop. But then, my tires were always under-inflated coming out of the dealership. It does seem strange to me, now that I'm seeing others experience it. However, I'm a mathematician; many of you should have heard the phrase "correlation does not imply causation" and I'm sure plenty of people can describe dealer trips after which their mileage remains unchanged, and I can certainly describe times my mileage has taken a nose dive for reasons that are certainly NOT dealer-related. ~ dan ~ I conclude that if there's a causal relationship, it's a serious, but accidental, cause.
Yeah, that would really do it. I do not know if anyone has run a controlled experiment of seeing what the MPG changes are depending how what viscosity oils are put in. If someone has I would really like to know about it.
I also got poorer mileage after the 5000 mile dealer oil change on my 07, but put it down to the colder weather, since I do not keep very accurate mileage records. However, they did tell me that there was an upgrade to the computer that they did. I would guess that upgrade would apply to all 07's. I wonder if that could have caused your problem.
I have a 2007 and had it since Sept. I got a 5000 mile oil change at a local Quick Change; due to the fact that my dealership is a 40 min drive each way. i have not noticed a MPG drop due to this, but have due to the weather dropping. i will be blocking the grill later this week. if you use synthetic oil can you go to 7500 miles? i know the manual states 5000, but isn't that with regular oil? What are the benefits to using synthetic with such a small motor? if i do go back to reg oil, should I change it after 3000 miles or stay with 5000? Thanks
I know for a regular vehicle with a full-time ICE (like my Mustang) it can benefit from ultra-light 0W-30 synthetics, so that you have oil pressure the instant you start cranking the engine. I don't see how it would benefit the Prius, because it does all its stopping and starting after it's warmed up, when the oil is at its higher viscosity number. ~ dan ~
Whenever you talk about extended oil change intervals, get ready for a lot of comments on invalidating the warranty. It does not invalidate your warranty but you should know exactly what oil is being put into your car if you do so. 0W-30 or 5W-30 synthetic are the common choices for extended intervals. In very cold weather 0W-20 has been used by some. Right now my program is to change the oil at 10,000 mile intervals. I use AMSOIL Synthetic 0W-30 and have the oil tested to ensure it is still in very good condition for extended intervals. As a last note, The 2001 Prius (with the exact same engine as a 2007) has the Toyota Oil Change interval being 7500 miles, so what you are wanting to do was standard practice. The reason for the change to 5000 had nothing to do with the Prius, but due to problems Toyota had with big engines and bad oil and the Prius is an innocent victim of that. If you want more info, search for posts by jayman. You do not need to change at 3000 miles, you are just wasting oil by doing that. For 5000 mile intervals, either synthetic or regular will work fine. It is the longer intervals (10,000 or more miles) that synthetic is the better choice.
That's amazing! My MPG's have dropped a little too, but I figured it was mostly due to tempreture. How do I check my air cabin filter? I'll admit - I haven't searched yet, but I am about to! Edit - using John's site - it's the filter right behind the glove box, no?
Thanks. I'm going to check mine today. I would have NEVER thought that would affect one's mileage so much.
That's what I'm curious about the most. But it seems to have helped the OP. It was the only variable that was changed in the entire equation AFAIK...
The ONLY thing I could even think of or google would be if it was so clogged that it caused the AC to go into overdrive causing more engine use, etc.... But, for something so simple, why not check?
I change mine every few months. Made a slew of them out of furnace filters. We had some fires locally, and that filter really got dirty.
Rxmxsh - Your avatar just COMPLETELY FREAKED ME OUT. It must have had EXACTLY its desired effect on me. First, I thought there was a bug on my screen. But the slight discoloration of the transparency made me think somehow it was flexing my TFT. So I was kinda wigged out. Then I wondered why it wasn't moving away from the bottom-left corner of my screen. It was too weird to watch, so I decided to puff some air on it to remove it. When it didn't pop off, I went to put my finger on it and realized it was, in fact, just some genius' avatar. Well played I think once I determined it had to be a real bug, I never once went back to the concept that it could be on my screen. Maybe at 27 my eyes are starting to go; either way it's certain my brain is. ~ dan ~
Adding more details and thoughts... First, the CAF change was made by itself... one variable at a time. At this point, several weeks later (with time off for a Christmas jaunt down to Tulsa), MPG remains around 42-43, which is a bit worse than I was getting before the oil change, but substantially better than I was getting after it. The oil change is still pending... possibly next week, with a new dealer doing the work (and with instructions derived from here). More details when that is final. Now, thoughts on the difference.... When I had the dealer check on the MPG, the mechanic said he'd gotten 53 MPG, and that's what the display showed when I headed out. I remember that I had to turn on the blower... he'd turned the heater completely off, which would (if my mind is working correctly) take the CAF completely out of the picture. No air, no need for the CAF, no impact. Because the CAF was so clogged, there was little to no air going through it, which *may* have been causing *something* else to run even harder to try to push or pull air through. The ICE may also have been running more often to try to get the temperature to the desired level. Since the CAF change, I've also been running the heater lower and slower... that is probably also having an impact. Frankly, I hadn't thought to check it previously... I don't think I've owned a car that had one, although I think my Saturn had to have its CAF cleaned out a couple of years ago. I'll be checking it a lot more now, along with the EAF. As for the simplicity of checking it... well, since I don't know *exactly* when the junk got in there, I have no way of telling if the dealership actually checked it or not. They've left no real record for me... hence the next oil change at a different dealer. Every day, something new to learn...
:lol: That just made my night! lol - Believe me, you aren't the first person to try to kill the bug on their screen. ^_^ But you are the first that I know of to puff air at it!!
HAHA... Now let it just be understood that I'm going to get you... some time or another. Be glad I'm sitting on an airplane waiting to taxi onto the runway. I couldn't possibly do anything about chasing you down, unless you happen to be in Chicago. ~ dan ~
