Do I have OEM Wiper Blades?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by dwillem, Mar 12, 2021.
Tags:
  1. dwillem
    dwillem New Member
    Los Angeles
    I just got a 2012 C2 last week. It was my sisters car, she was the original owner. I want to replace the wiper inserts but before I order the OEM refills, I need to make sure my car still has the OEM wiper blades. How can I tell? My sister has no clue if they are the original wiper blades. I have spent so much time reading posts and and looking at parts websites and I am lost. Front C2.jpg Rear C2.jpg
    Can you tell by looking at them? Or If I take them off will they show Toyota branding? I have attached photos. Are they OEM blades? Will the OEM refills work?
    #1 dwillem, Mar 12, 2021
  2. Tideland Prius
    16,684
    Well given that your sister doesn't know, I suspect it's original. The rear looks OEM. The front most likely are. People usually change the wiper arm for aftermarket ones either because it broke (collision or just user error) and they didn't want to use an OEM one, or they replace it with those that have the spoilers that help push the blade down the windshield as it wipes (using the airflow as the car drives as the mechanism to push the blade down.
    If they're OEM, of course the OEM blade refills will work.
  3. PriusCamper
    PriusCamper Senior Member
    13,479
    5,446
    Pacific Northwest, USA
    Why would you want cheap garbage OEM blades when there's so many better more modern options?
  4. dwillem
    dwillem New Member
    Los Angeles
    Thanks. They look OEM now that I looked more closely and saw what the OEM ones look like on a video.
  5. dwillem
    dwillem New Member
    Los Angeles
    I didn't realize they were garbage. I thought maybe I shouldn't discard an OEM part off the car (the wiper blade) but if they are junk.... I'll take your advice and just get some good ones from the parts store. Thanks!
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Because not everybody shares your twisted opinions. :eek:
    Over the years, I have had much better "luck" with OEM refills on almost every car I have owned.
    I buy mine at the dealership and install them in the parking lot so I can take them back immediately if there is a problem.
    Note: Incase you haven't noticed, wiper "refills" and really hard to find these days.
    All the major parts stores want to sell you a whole assembly; sometimes the whole arm.
    PriusGuy32 and durr like this.
  7. dwillem
    dwillem New Member
    Los Angeles
    The main reason I want to keep OEM blades is aesthetics. I like the way they look. Some of the aftermarket blades look different and won't have the same finished look. And shopping online, you don't really know how they will look. Another reason is that I could get all 3 refills from Toyota for like 23 bucks. Come to think of it, I've had two brand new Toyota trucks in my time and I don't recall ever thinking the wipers were problematic. Maybe I'm just not as discerning as some. The wipers and defrosters on old cars were so terrible, all new cars are a dream to drive in the rain to me.
    And it seems wasteful to throw away the entire plastic blade every year or more when just the rubber is bad. throw away generation...
    #7 dwillem, Mar 14, 2021
  8. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    Toyota OEM wiper blade is on top,
    Bottom blade is TRI-CO Exact Fit
