Do I have to buy coolant from Toyota Dealer
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pjsluna, Jan 26, 2007.
  1. pjsluna
    pjsluna Junior Member
    My coolant tank level is a little low. When I read the manual it of course mentions you have to buy the coolant from toyota dealers.
    I don't have the manual inside right now but it seems like there are two coolant reservoirs? Do they both take the same coolant?
    Do I have to buy coolant from Toyota or are other brands with similar constitutents ok?
    Please advise
    Thank you!
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(pjsluna @ Jan 26 2007, 04:22 PM) [snapback]381333[/snapback]</div>
    2 reservoirs? There's just one that I saw, and it should have reddish coolant in it. I only use the red stuff from Toyota in all my Toyotas. If it's under warranty they might top it off for free. Maybe the other reservoir you are seeing is for the windshield washer?
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< I believe there are indeed two coolant reservoirs, one for the ICE and another for the Invertor [which converts the 201 volt DC from the main traction battery to as high as ~500 volts AC].
    In adding coolant to the Prius, I wouldn't mix another brand. The Prius coolants are ultra-long-life. Both ICE and Invertor coolants aren't scheduled for replacement until your reach 100K miles or 120 months.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Tell you the truth if it's only"a little low" I wouldn't touch it. I believe and somebody correct me if I'm wrong, that the inverter coolant is different from the ICE coolant. I would just let the mechanics look at it when you get the oil changed.
  5. pjsluna
    <div class='quotetop'>QUOTE(paprius4030 @ Jan 26 2007, 02:13 PM) [snapback]381363[/snapback]</div>
    OK To clarify
    There are two reservoirs with reddish coolant...one next to the radiator (I ASSume is engine coolant reservoir #4 on picture on page 392 of manual) and one to the left of the HSD drive thingy (that's technical eh?) which is #5 on pg 392 and referred to as inverter coolant reservoir.
    Both contain the pinkish fluid....I know its a dumb question but is it the same coolant for both reservoirs?
    The one that is at low is the invertor coolant reservoir...
    I am happy to buy it from toyota but the dealer is a long ways away and Kragen is right around the corner so I thought I'd ask...
    PS....already have done a DYI oil change per directions from your lovely sight!
    Thanks again
  6. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    For the current model Prius, the coolant in both systems is Toyota SLLC, mixed 50% with distilled water. It may be sold in the bottle at this concentration. Substituting any other fluid type seems inadvisable.
    The classic Prius used Toyota type LLC but this can be upgraded to SLLC without any issues, AFAIK.
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(tochatihu @ Jan 27 2007, 07:43 AM) [snapback]381643[/snapback]</div>
    wrong SLLC is pre mixed do not dillute with water.
  8. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    don't put the green stuff in. ever. so yeah, you've gotta get the toyota branded stuff.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(galaxee @ Jan 27 2007, 04:55 PM) [snapback]381751[/snapback]</div>
    Oh geez, never ever. The silicates could form a nasty gooey sludge when they encounter the organic acids. Yuck.
    It's unclear if a similar coolant like DexCool is compatible. Considering how much is at risk, use the dealer coolant, which is usually sold premixed with deionized water in sealed containers.
  10. Mitchell1971
    Mitchell1971 New Member
    Modesto
    I have an 06 Toyota Prius I took the coolant out of mine and used coolant that that that use in a 2015 Honda Accord is that okay
  11. bisco
    51,155
    probably not.
  12. Mendel Leisk
    40,584
    The Owner's Manual doesn't empatically say you can't use alternate fluids, but after the "or similar" there's a lengthy description of all the factors the alternate fluid should fulfill. Maybe scare tactics, who knows.
    If you opt to go back to Toyota fluid, you're now in a bit of a quandry: the "Toyota Super Long Life Coolant" only comes pre-mixed (as far as I know). So if you were to flush the system with water, residual water would dilute the mix when you refill, and by how much is hard to tell.
    I'm not sure what the best course would be. Maybe: drain the best you can, all you can. Refill with TSLLC. Drive it a week or two. Repeat.
    Some info, mostly over my head:
    The Ultimate Coolant Color Guide | Toyota Parts Center Blog
    Some discussion here, not fully resolved, as to the compatibility of Honda and Toyota coolant:
    http://www.toyotanation.com/forum/80-89-95-toyota-pickup-hilux/317823-difference-between-honda-toyota-coolant.html
    Was the Honda stuff you used blue?
    #12 Mendel Leisk, May 24, 2018
  13. Mendel Leisk
    40,584
    The stuff I have on hand:
    The fine print, not that helpful:
    #13 Mendel Leisk, May 24, 2018
  14. Prius7Prime
    Prius7Prime Junior Member
    58
    Long Beach
    2012 Prius Alpha
    You can probably find the coolant online at https://www.toyotapartsprime.com/ but these types of fluids are considered hazmat from what I understand so there may be issues shipping them out FYI. Hope this helps.
  15. Mendel Leisk
    40,584
    Any local dealership would stock it.
  16. Prius7Prime
    58
    Long Beach
    2012 Prius Alpha
    Correct. Dealers should have it available.
  17. Petrodollar
    Petrodollar Member
    53
    46
    Four Touring
    Valvoline Zerex Asian Vehicle Antifreeze / Coolant
    "ZEREX™ Asian Vehicle has been designed to meet the requirements of Asian manufacturers, which specify a silicate free HOAT formula with a phosphate additive to protect their cooling systems from rust and corrosion. Available in both red and blue formulas to better match your Asian vehicle’s specific requirements."
    (Valvoline&trade; ZEREX&trade; Asian Vehicle Antifreeze / Coolant : Product Catalog - Valvoline&reg;)
    Product Information Sheets
    (PI Sheets)
    Valvoline Zerex Asian Vehicle Blue [Red] Antifreeze Coolant
    (US_VAL_ZXASIANBLUE_AFC_EN.docx - SpringCM)
    Napa - Zerex Asian Vehicle Red Ready To Use Antifreeze - 1 gal, ZRX 675130 $14.99
    (https://www.napaonline.com/en/p/ZRX675130)
    Advance / Carquest - ZEREX Asian Vehicle Red Ready-to-Use Antifreeze/Coolant (1 Gallon), 675130 $16.99
    (Advance Auto Parts - Down for Maintenance)
    Or Toyota OEM:
    Super Long Life Coolant (1 Gallon)
    00272-SLLC2 $23.43 (Toyota List)
    00272SLLC2 - Super long life cool. Maintenance, fluids, filters, coolant - Genuine Toyota Part
    #17 Petrodollar, May 24, 2018
    j12piprius likes this.
  18. Mendel Leisk
    40,584
    How about Honda coolant, any thoughts?
  19. Petrodollar
    Petrodollar Member
    53
    46
    Four Touring
    Only by inference. The Zerex Red and Blue are the same except for the dye color. If Toyota is red and Honda is blue, and the same Zerex is specified for both, then it implies that the Honda coolant is the same or very close to the Toyota. But that is only by deduction. You know, ... ducks, witches, and so on.
    skepCS and Mendel Leisk like this.
  20. Mendel Leisk
    40,584
    It'd be nice if there was a database on compatibility, this comes up quite often.
