do I have to run 100% gas 2012 prius c?
Discussion in 'Prius c Fuel Economy' started by mom2chrisnben, Aug 24, 2015.
  1. mom2chrisnben
    mom2chrisnben New Member
    mustang ok
    I recently bought a 2012 prius c and have started thinking, if it was possible for me to run successfully some of the other choices avail at the pump other than 100% gas. Does anyone have any insight into this? Thanks.
    Michelle
    52,914
    welcome! nope. are you considering diesel or kerosine?
  3. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    Your car is designed to run on E10 gas. That is 10% ethanol. We don't like it, but it works fine.
    X
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    E10 gas is fine. More than 10% ethanol is discouraged by Toyota.
    (it will get about 4% less fuel economy than pure gas but usually cheaper per mile)
  5. bisco
    52,914
    and you will get 10% less mpg's. what the price diff?
  6. mom2chrisnben
    mustang ok
    at this point I would like to take all my options into consideration. can I successfully long term run e85 or diesel or another form of fuel other than regular 100% gas.
  7. bisco
    52,914
    not successfully, without some changes.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Diesel is always a bad choice.
    Toyota does not think you can run E85. If your warranty is up, (60,000 miles) then their opinion does not matter as much. Best of luck. (if you find a E85 conversion for a Prius, expect 30% lower MPGs)
  9. mom2chrisnben
    mustang ok
    The mileage when I bought it was over 81k. I am currently seeing about 42 mpg on 100% gas. at about 2.85 per gallon.
  10. mom2chrisnben
    mustang ok
  11. bisco
    52,914
    how much diesel would you mix in?
  12. mom2chrisnben
    mustang ok
    what ever amount would not kill my car and still lower my fuel bill. therefore whether it is 100% gas or e85 or diesel or any combo there of. I am not a tree hugger by any stretch of the imagination I am interested in saving money and social responsibility as long as it doesn't hurt my family's overall financial situation.
  13. ETC(SS)
    7,581
    First of all.....diesel is more expensive than gas, so I'm not sure what you'd accomplish by trying to use it as fuel in a "C-Type" other than a good way to see if the "check engine light" or CEL is working.
    As far as E85?
    Bob Wilson did some tinkering with this a while back, and I'm thinking that he's not using E85 now.
    Read up on it yourself and TIFWIW.
    Me?
    I like posts like this because all of the financial experts out there say that it's moronic to buy new cars instead of used ones----and they're right.
    However (comma!!!) there are enough people out there who engage in physics and chemical experimentation with their cars that I can use as an example to my CFO when it comes time for me to retire one of my vehicles, that I'll be able to get a nice new one instead of a "gently" used one.
    Your car.
    Your call.
    I don't.
    I won't.
    Good Luck!
    #13 ETC(SS), Aug 24, 2015
  14. bisco
    52,914
    is this something you've tried with other vehicles?
  15. mom2chrisnben
    mustang ok
    no I have not tried doing my own combo of anything, I have just been thinking "There has to be a way to get better gas mileage and spend less every time I fill up." I would prefer to have a cng car or even a full ev but I don't have either or the current choice of either. I usually run 100% gas because it will go farther for the price, however if an ethanol blend is cheaper in the long run by either mpg or ppg then I will go with the cheaper option.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    81k is a little short to need a 'major tuneup'
    http://www.toyota.com/t3Portal/document/omms/T-MMS-12PriusC/pdf/2012_Toyota_Prius_C_WMG.pdf
    at 90,000 miles it needs a new air filter (page 49)
    at 100,000 miles you should replace both coolants, engine and inverter (page 50)
    at 120,000 miles it needs new spark plugs and another air filter (page 53)
    You might consider doing the plugs and filter early to improve MPG
    but I suspect you are just driving it short distances.
  17. Mendel Leisk
    42,382
    I'd say it's designed to tolerate gas with up to 10% ethanol. It'll do better with 100% gas, and I believe that's what's used in the mpg tests. All moot, since 100% gas is rare, and expensive if you can find it.
  18. mom2chrisnben
    mustang ok
    yes, most of the time I am driving less than 22 miles per day round trip for work.
  19. mom2chrisnben
    mustang ok
    99.9% of the stations in my town sell 100%gas alone or along side blends.
  20. bisco
    52,914
    i suppose you'd have to run some mpg trials to see which is more economical. unfortunately, you're driving the most economical car on the road. gonna be tough to improve on it. pump up your tyres and through all the excess weight overboard.
    mom2chrisnben likes this.
