Do I need a new hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ronnyrado, Aug 21, 2023.
  1. ronnyrado
    ronnyrado New Member
    Denver
    I drive a 2008 base model Prius and it’s been great. I’m at around 243,xxx miles now and we replaced the hybrid battery once (with a refurbish) at about 170,xxx.
    Just a few weeks ago, all the hybrid warning lights came on, red triangle of death, check engine, warning light on infotainment screen. The gas mileage is still about the same - around 43-48, depending on how it’s driven.
    I did a Dr. Prius code read on it and shared the results with the guy who I bought the first refurbish from to see if I need another new battery. He said the results indicate that it’s still in good shape and the issue resides somewhere else, and discouraged from buying a new battery yet.
    I went and tested my 12v battery and it seemed to be time for a replacement, so I got a new AGM battery. While driving it around to get the battery and such, the acceleration lag got continually worse until it was in limp mode.
    I am college student so money is tight haha and I want make sure I am putting money in the right places. So I’ve come to the Prius masters - what should I do next? What should I check and what could this issue be?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Share the codes with us? It would help a lot for us to give you an accurate assessment.
    P0A93 by chance?
    P0AA6?
    jerrymildred likes this.
  3. ronnyrado
    Denver
    Good point. The codes I got back were:
    P0A80
    P3022
    P3016
    I've also attached some screenshots from the Dr. Prius app.
  4. Brian1954
    Brian1954 Senior Member
    2,673
    1,069
    South Central PA, USA
    Those three trouble codes indicate problems with the battery modules in blocks 6 and 12. It is time for a "new" refurbished battery OR a new OEM battery.
  5. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Yeah, that guy blew smoke. Those are 100% HV battery failure codes. It's a bit surprising that anyone who works on these batteries doesn't recognize these as HV battery codes.
    P0A80 is actually P0A80 and is "Replace hybrid battery"
    P3022 = Battery Block 12 weak
    P3016 = Battery Block 6 weak
    Brian1954 likes this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,085
    6,947
    Texas Hill Country
    73k miles on a used battery is pretty good. That kind of battery is worth maybe $900 with a warranty. Did he give you a “lifetime“ warranty? If so he is trying to avoid your claim.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    You can monitor block voltages while driving - particularly hard accel and decel. You will likely see the "bad" block voltages drop 1.0-1.5V lower than others on accel, and go higher than the others on decel. This would confirm that the codes are condemning a failed Hv battery.
