Do I need the whole TPMS sensor to fix air valve?
Discussion in 'Gen 3 Prius Technical Discussion' started by kikik, May 24, 2018.
  1. kikik
    kikik Junior Member
    83
    44
    Maine
    Hmm...the tire is in the back of the car. I only drove around my neighborhood to test whether the spare would come off or not but there were no lights on. WEIRD!!
  2. fuzzy1
    10,452
    It likely hasn't had time to be certain that a sensor is missing. A few miles on the spare will fix that. Maybe faster if you leave the flat tire in the hatch area and it picks up the low pressure from it.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    The TPMS system should immediately alert if there is a low pressure at one of its sensors. Maybe breaking the stem caused another issue with the sending unit. If a sensor is missing in action, the system tried to communicate with it for about 20 minutes of continuous driving before it gives up and triggers a warning light. After all, it is logical that your tires are supposed to be on the car ;)
  4. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    As Mendel said, spare does not have TPMS in it. The low tire pressure warning light, looks like below should come on soon after car starts.
  5. kikik
    kikik Junior Member
    83
    44
    Maine
    No, I drove around maybe 5 minutes? or so and I was VERY alert of the dash lights because it was my first time changing out to a spare on my own so I was scared the spare might go flying out or something. But nothing, not even a single blink or anything. Oh but when this happened EVERYTHING blew out of that tiny hole. The little thing (image 2) that was inside hit me so hard it left a mark over my shirt! hurt SO..MUCH... Maybe something else blew out that I was not aware of while I was crouching in pain and trying to get back in to reality that I missed it and broke the sensor? I'll ask about that when I get it fixed.
    It's going to be 83 here in Maine today!! Yay! Yesterday was like 50!!
  6. Mendel Leisk
    41,457
    For removing the remaining valve caps:
    First off, it might be good to remove the wheel cover, grab in a couple of openings, and yoink quickly. Hopefully will pop it off.
    Then to remove the caps, if possible, restrain the valve stem from turning, by clamping it with a pair of bent tip pliers, below the cap, just tight enough to restrain it from turning. Then with a second set of pliers (or a ratchet wrench and socket, if you can find the right size, might be 3/8" or 10 mm), grip the cap and try to break it loose.
    If the valve cap is just metal, carefully applying heat with a propane torch might expand the cap enough to help break the bond.
    Video encompassing all of the above:
    @kikik, whether you or tire shop, I'm guessing this is how it'll get done. Again, they really should not be selling these metal caps; they should be banned. :mad:
  7. Salamander_King
    11,019
    8,954
    New England
    As suggested above, something might have gone wrong with the sensor unit sending signal to car's control unit. It may take longer than 5 min for the car to realize that there is problem with one of TPMS. Of course, this is a problem on its own. Registering TPMS malfunction should be immediate if it is there to warn you in an event of lost tire pressure. Have them checked out at wherever you are planning to take the car for repair.
    BTW, the thing flow out and hit you is the core of stem. That should not be the part of TPMS sensor itself. Actual TPMS sensor is the black bottom part of the last figure you posted. Wish you the best for repairing your tire and.
    At the least some warning label especially in areas with winter road salt.
    #27 Salamander_King, May 25, 2018
  8. kikik
    kikik Junior Member
    83
    44
    Maine
    Thank you!! Yes, will definitely try heating it up first but will it affect the TPMS with the heat? I also thought I might dremel it and just cut it off?
  9. VFerdman
    VFerdman Senior Member
    1,186
    1,215
    Western Massachusetts
    Or they could redesign them with plastic/silicone covered threads or something. But as long as people buy them, they'll keep making them. Like Doritos. Just because it's crap doesn't mean they will be banned. People need to stop buying them it's that simple.
  10. VFerdman
    1,186
    1,215
    If you apply heat very sparringly like with a bic lighter, not a torch it should be okay. They idea is to heat only the cap and not let the heat go further.
    I like the dremel idea. But also very carefully cut with the slowest speed and across the path of threads and I would try to not go all the way through the cap, just enough to weaken it and then take the pliers and squeeze such that the cap would break where the cut/score mark was made. I would also try all manner of penetrating oils. Liquid wrench and such. It may just work that way.
  11. kikik
    kikik Junior Member
    83
    44
    Maine
    Ok, I got a quote! If I wanted the OEM it will be $57.80 if it's a third party sensor its $48. Which should I choose??!! If it's only $10 difference go with the OEM?
  12. Mendel Leisk
    41,457
    Yeah I would go OEM. Is the OEM quote from dealership, or both quotes from tire shop? If tire shop, are they confident they can get the new sensor intitialized, recognized properly by the car. Hope it works out for you. (y)
    I'm almost assuming it must be tire shop for both quotes. A dealership, I'd guess they'd be asking around $200??
    See too if tire shop can remove the other valve caps.
    This is my weak spot:
    I walked by a display of them in Rona yesterday, it was tough...
    #32 Mendel Leisk, May 25, 2018
  13. Salamander_King
    11,019
    8,954
    New England
    I would definitely go with AFTER MARKET with TWO piece TPMS and stem system. That way, if you have to change the stem, you do not have to buy new TPMS. BUT if the LOOKS is important, and you really want all 4 stems to look the same, then go with OEM. However, there are aftermarket TPMS with aluminum stem that looks almost identical to the OEM if that matters to you, but rubber stem is better against salt corrosion and cheaper.
  14. kikik
    kikik Junior Member
    83
    44
    Maine
    The OEM doesn't have 2 piece, they're saying it's the same one that I had on. The third party one does though...
  15. Salamander_King
    11,019
    8,954
    New England
    Sorry, I typed too fast... I corrected it. Read my comment again.;)
  16. Mendel Leisk
    41,457
    I was thinking about this too, similar story:
    Metal valve stem caps. Ugh... | PriusChat
    People are just wandering around automotive accessory aisle, looking for something nice for their car, and pick up some dressy metal valve caps on a whim, they should ban these.
  17. kikik
    kikik Junior Member
    83
    44
    Maine
    I just went out and looked, it's covered in dust and dirt so prob wont make a difference in looks? It'll look grayish in no time? lol!! I think I'll try the third party because I want it done NAO! the OEM it takes 2 business days.
  18. Salamander_King
    11,019
    8,954
    New England
    Yeah, I remember this thread. OEM TPMS comes only with aluminum stem. It does look nice, but for winter road salt area like OP lives, time tested rubber stems works much better. IMHO
  19. Salamander_King
    11,019
    8,954
    New England
    GO FOR IT. It means they have to order OEM TPMS, but have aftermarket one in stock.
  20. kikik
    kikik Junior Member
    83
    44
    Maine
    Wow! That person had to pay $400 for 2? I feel like I'm getting a bargain with just $50...even if I do all 4 it's just for 1 price!!
