Do I need the whole TPMS sensor to fix air valve?
Discussion in 'Gen 3 Prius Technical Discussion' started by kikik, May 24, 2018.
  1. Mendel Leisk
    41,457
    That's through dealership, and yeah, my $200 guesstimate up the page seems about right. Is your estimate from a dealership or tire shop? I'm really suspecting the latter. That's not to say they won't do it right, get the sensor initialized properly, but verify with them: have they done Toyota sensors before, are they confident it will work, guarantee it?
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    TPMS in each wheel has limited life span of battery inside. The battery cannot be replaced once dead. Whole TPMS has to be replaced with new one. I made mistake on my previous first TPMS sensor equipped car some years ago by taking it back to a dealer, costing me $200/visit x 4 = $800 when this could have been done ~$200 total at a local tire shop.
  3. kikik
    kikik Junior Member
    83
    44
    Maine
    I got it done! I went straight to the store after and picked up some jack and wrench and other supplies so I can get ready to replace the other 3 tires! (hopefully NOT) So I asked why the light didn't come on my dash and the man said, it may be that the wind force jammed something and pressure was there or so many other possibilities but everything is working and that I don't have to worry about it and I can throw away the remaining parts. It only took 30 minutes and on that same day!
    The look....yeah don't like it LOL! It's probably because it's brand new and the black color stands out. I'm sure when it gets covered in dirt it'll be ok but the most I don't like is the stem is longer than the OEM. It makes it even more stand out. But if I change out the other 3....they'll all match!! Ha!
    We're going on a road trip this weekend so I'm not going to mess with the other caps until we get back.
    Mendel Leisk and Salamander_King like this.
  4. Salamander_King
    11,019
    8,954
    New England
    Sound like it is an aftermarket TPMS with rubber stem. Yeah, the looks hurt, but that long stem is much easier to take off a cap and check pressure and/or put air in with air compressor. Believe me, been there, done that! ;)
  5. fuzzy1
    10,452
    Not long enough for a missing sensor. While I never timed the cases when I forgot to reprogram after seasonal tires swaps, I've certainly driven more the 5 minutes before my TPMS alert came on. (Maybe 10-15 minutes? I went almost 10 miles down the highway, but there are 5 stoplights between me and the highway on-ramp.)
    A low pressure reading should trigger an immediate alert once the car receives the signal. But a loss-of-signal condition is not alerted immediately, the car gives it a while for multiple tries.
    I.e. he doesn't know how it works either. Don't believe those ideas.
  6. Salamander_King
    11,019
    8,954
    New England
    Yeah, I know, but she said she had the flat tire with broken stem TPMS in the car all that time. In any case, it is now a moot point. She has a brand new TPMS.
    #46 Salamander_King, May 25, 2018
  7. Mendel Leisk
    41,457
    I don't get that too: as soon as the car doesn't get a sufficient pressure signal from any of the four sensors, the warning light should go on. That's the object of the exercise.
    We live with that light 4~5 months of the year, with snow tires on the car.
  8. kikik
    kikik Junior Member
    83
    44
    Maine
  9. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    @fuzzy1 has it...it can take a 20-30 minutes drive for the TPMS computer to sort out a non-working TPMS.
    TPMS responds quite fast as far transmitting pressure data, but if no new data is being transmitted, then that takes the computer more time to figure out that a lack of data is happening. Also it might be possible fake a pressure reading in certain failure modes...I do this intentionally with a TPMS in a binder clip for one of my tires.
  10. Mendel Leisk
    41,457
    I seem to recall, when switching over to snow tires (on separate rims, no tpms) it can take a few minutes to get the light. Maybe. The regular wheels/tires are in a stack directly adjacent to the car where it's parked too, likely a factor.
  11. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I checked Techstream and I have one sensor with low battery. Every morning when I drive to work, the TPMS light would blink right from the start and for a while then becomes solid. I didn't time it, but certainly within couple mins.
    Raytheeagle likes this.
  12. Mendel Leisk
    41,457
    That's kinda early. I think right now it's typically 07~08 at the latest, starting to see battery failures.
    I'm almost waiting on ours to fail, so I can replace with regular. There's no inspection or regs about tpms up here.
  13. kikik
    kikik Junior Member
    83
    44
    Maine
    It's $50 and if you'd had to do it sooner or later you should just get it done than to deal with the annoying lights every freaking dayyyy!!! would be my thought.
  14. kikik
    kikik Junior Member
    83
    44
    Maine
    BTW what is Techstream? Is it better than this?
  15. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Yes;).
    It’s the most powerful diagnostic tool you can get for any Toyota, Lexus or Scion vehicle:).
    Paired with an old laptop and you’ve got what the professional mechanics have(y).
    Salamander_King likes this.
  16. Salamander_King
    11,019
    8,954
    New England
    Techstream is an official Toyota diagnostic system. You can get it official version from Toyota for hefty subscription fee, or get rip off version from ebay. It has way to communicate with car's computer and allows you to diagnose many, many things, so I hear. I got one of those cheapo rip off version off eBay, but yet to be able to work on my old laptop. ScanGuage is third party diagnostic tool, also very popular among Prii owners and any car enthusiast.
    #56 Salamander_King, May 25, 2018
  17. kikik
    kikik Junior Member
    83
    44
    Maine
    Ahhhh but I don't have Windows....you can't program with a Mac right? Hmm...interesting...I was planning on getting the ScanGauge2 but...
    Salamander_King and Raytheeagle like this.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    There are ways around that issue;).
    There are plenty of old laptops to be had (my in laws had one they didn’t want so I have it for our Techstream setup):).
    Now all that laptop does in life is run Techstream ;).
    Currently being used to rebuild a pack by another member:).
    It can be a bit fiddly to get going, but once you do, you have EVERYTHING you’ll need(y).
  19. kikik
    kikik Junior Member
    83
    44
    Maine
    Yes, but I want to read temperatures, MG1, MG2 etc so I think I'll get the Scangauge first.
  20. kikik
    kikik Junior Member
    83
    44
    Maine
    Yes, I'll have to look this up more. VERY intriguing!!
