Do I need to do anything special to bleed front brakes only?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matt98svt, May 17, 2026.
  1. Matt98svt
    Matt98svt Junior Member
    98
    South Carolina
    2015 Prius v wagon
    Just picked up a 2012 prius and replaced the front pads and rotors, the rear were already done at toyota this past year. So Im only looking to bleed the front brakes. Do i need to put the car in service mode or anything special if im only bleeding the front two calipers? I know it has electronic brakes in the rear but from what I recall the front on normal so I gather I can pump the brakes with the car off and just open the bleeders to bleed them? Thanks in advance
  2. ChapmanF
    19,026
    Did you open the hydraulic connections at some point of your pad-replacement job? Bleeding is only needed if you did and air could have entered.
    The system is electronically controlled front and rear. What's different about the fronts is that there are two front hydraulic circuits: the one used when the brakes are operating normally, and the one used as a fail-safe during fault conditions.
    The fail-safe circuit behaves like conventional car brakes, when the car is off. If you "pump the brakes with the car off and just open the bleeders" you're bleeding that circuit. That's not the one used in normal operation, though.
    If you're sure the only air in the system is down at the caliper ends of the lines, it can still be enough to get that air out.
  3. PriusCamper
    PriusCamper Senior Member
    13,466
    5,433
    Pacific Northwest, USA
    I'm glad we agree on not needing to bleed the brakes when changing brake pads. Suspect cars a 1/2 century ago probably weren't as reliable with hyrdalics and flushing and bleeding was part of every break pad change.
  4. ChapmanF
    19,026
    I often will open the bleed screw while pushing back the piston for a pad replacement, so I am not forcing the fluid from the caliper back upstream into the high-rent parts of the brake system.
    But if I'm going to do that, I start with an upward loop of fluid-filled hose attached to the bleeder, so when I open it there will be no air going in, and only fluid coming out. Then I can just close the bleeder again, with no need—as I guess we agree—to do any brake bleeding as a follow-up.
    CR94 likes this.
  5. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    I do similar on these abs car
  6. PriusCamper
    13,466
    5,433
    I have a hard time believing that forcing the fluid back to reservoir with the 12v battery disconnected is going to be a problem? I've done both gen2 and gen3 with the simple tool to press the calipers apart with a thumb screw and it's always been an instant increase in fluid in the reservoir. It's kind of like that rule of cracking the reservoir fill cap before you push the caliper pistons back. It's a good idea, but the fluid going into the reservoir isn't goign to compress much air.
    However your method would make sense one time I did brakes and the fluid was topped off in the reservoir and the new brake pads pushed the reservoir to overflowing. But a turkey baster could solve that faster than a hose on a bleeder nipple, especially in climates that are prone to rust and corrosion.
  7. Tombukt2
    13,864
    2,519
    Durham NC
    Just crack the passenger side front bleed screw first let drip 3 min do other side front same amount. Should be
  8. Mendel Leisk
    42,350
    Not sure there’s any need to do this, replacement of front pads and rotors wouldn’t necessitate any expelling of brake fluid. Some like to, to flush debris. Ive never bothered (over the years, various cars), with no apparent downsides.
    a full brake fluid replacement is something to consider though: while Toyota USA says nothing about it, Toyota Canada now recommends tri-yearly or 48k kms (~30k miles), whichever comes first.
    there’s a link in my signature regarding brake fluid change (on a phone turn it landscape to see signatures).
    (there’s a mention of “pint bottles” (16 oz) of Toyota DOT3 fluid, in fact they’re 12 oz. A couple of those is how much I’ve used, seemed sufficient. You might want to use more, especially if it’s never been done.)
    #8 Mendel Leisk, May 18, 2026
    Tombukt2 likes this.
