Do Not Create Multiple Accounts
Discussion in 'PriusChat Website Questions' started by TonyPSchaefer, Sep 19, 2017.
  1. ChapmanF
    18,754
    There doesn't need to be any fancy explanation for IPv4 addresses getting shared around. That's the normal state of affairs.
    You typically need to pay a higher rate to an ISP to get an address that doesn't change and is statically associated with you. Most people don't, unless they run services on their computers that other people need a static address to connect to.
    -Chap
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,522
    Bay Area, California
    2019 Prius Prime
    Was that you who took Tony's original avatar photo:sneaky:?
    Or you got some other photos to share:whistle:?
    bisco and RCO like this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    This is all quite true. @TonyPSchaefer may also be seeing the effects of ISPs or large companies using carrier-grade network address translation (CGN), which routes many users’ connections through a limited number of gateways, exposing only the IP addresses of the latter on the public Internet. Several of the IP addresses in the screen captures belong to T-Mobile, and they are known to use this technology, which avoids the need to assign, even temporarily, a unique, globally-routable IPv4 address to each subscriber.
    Another possible explanation, since PriusChat uses the Cloudflare content-delivery network, is that these IP addresses actually belong to servers that Cloudflare has placed inside (for example) T-Mobile’s network. I don’t know if the PriusChat origin servers have been set up to recognize the CF-Connecting-IP HTTP header that Cloudflare adds to identify visitors’ IP addresses, but if not, perhaps they should be.
    bhtooefr and RCO like this.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Dang! Back when I was working on ARPANET, an IP address was 8 bits. Nameservers didn't exist - names were compiled into every site's code. Baby's grown a bit.
    A few other famous last words...
    Why would you need 1200 baud? You can't read that fast.
    640Kb is more memory than you could ever use.
    Men don't need to learn how to type. They'll have secretaries to do that.
    Dial phone now.
    Ethernet will never work. With packets wandering aimlessly, some are bound to get lost.
  5. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    When I use my AT&T cell connection, anywhere in the Midwest or Colorado, the IP pops out of Texas. My T-Mobile line usually ends up in the nearest big city to where I am. Both of those IPs are publicly (what you're seeing) the same for tens of thousands of people, just the subnet IPs to the phones are different.
    When in university or at work, everybody in the building has the same IP address for the same reasons on a smaller scale.
    Ontop of that, lots of VPN use and Tor use means IPs pop out from all over.
    Using IP addresses to determine these types of things is completely archaic in today's day and age. It just plainly doesn't work.
    Raytheeagle and RCO like this.
  6. hill
    8,982
    So it's settled. TonyShafer is the actual clone & it's his evil twin that's trying to take the rest of us down & it's HIS account that must be deleted.
    Buaahahaha.....
    EDIT: i wonder if posts made via Tap a talk (mine are maybe 70%) are part of the cause .... though this edit is being made via Disney's server. Gotta mix it up to keep Tony off the scent.
    :coffee:
    #26 hill, Sep 20, 2017
    RobH, Raytheeagle and RCO like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Anybody got a teacup? I feel a storm brewing! :ROFLMAO:
    bisco and Raytheeagle like this.
  8. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Interesting, I first joined in '05, and I have multiple accounts because Prius chat kept cancelling them, or changing my name, and now it turns out as I knew all along, it was tony, he changes my conversations and deletes my username, where's the profit in that?
    RCO likes this.
  9. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Dangit! My devious plan has been discovered. That's what I get for drawing attention to myself.
    Oh sure, I lose on individual transactions but I make it up in volume! ;)
  10. bisco
    52,559
    i was really hoping you were going to bag a couple of these thorns. it's easier to discern them from their posts, than their ip addresses.
    RCO and Mendel Leisk like this.
  11. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    All three Five of those six of those IP address are in the 172.32.0.0/11 netblock, TMO9, owned by T-Mobile USA. The other one is in the 204.128.192.0/24 netblock, DISNEY-BUR5, owned by Disney Worldwide Services.
    Cellular IP addresses are highly dynamic (and, as @Elektroingenieur pointed out, carrier-grade NAT is likely in play, basically guaranteeing collisions), so I wouldn't rely on them for rooting out duplicate accounts.
    Not sure about the Disney one, though.
    #31 bhtooefr, Sep 20, 2017
    HTMLSpinnr likes this.
  12. hill
    8,982
    Thank you
    (the check's in the mail)
    I wonder if I could shake down T-Mobile for some cash for this besmirch'ing of my impeccable character.
    #32 hill, Sep 20, 2017
    jerrymildred and RCO like this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Where indeed? Who the devil knows. Wait a minute, @Lucifer you should! ;)
  14. bisco
    52,559
  15. TonyPSchaefer
    14,816
    2,501
    66
    To be clear, Hill, my intentions were not in any way an attempt to besmirch your impeccable character. You just happened to be lumped in when I was researching others. I've already said too much.
    jerrymildred likes this.
  16. bisco
    52,559
    disney character?
  17. hill
    8,982
    Impeccable - hahaha I crack me up
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Yer goofy! You know that? :ROFLMAO:
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not Walt tapping on a deserted keyboard? :sick:
    Raytheeagle and bisco like this.
