Do not use premium fuel on prius!!!
Discussion in 'Gen 3 Prius Technical Discussion' started by Ernesto Chavez, Jun 30, 2016.
  1. Ernesto Chavez
    Ernesto Chavez Junior Member
    24
    I have a 2010 prius with 180k miles that has worked flawless. I decided to start using premium fuel since its so cheap. Due to the 13-1 expansion engine ratio, (high compression engine) it started hesitating and having a rough start transition from hybrid to ICE power. It also sounded like my engine was going to tear to pieces! The sound lasted like 3 seconds most of the time. It also tripped a check engine light for cyl 1 and 2 misfire. Turns out that after research my mistake was using high octane fuel. I used up my old fuel as hard as I could drive it, refueled with 87 octane and I'm back to a super smooth and happy hybrid. Also stick to 0W20 motor oil.
    myPriusAcct likes this.
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    wow, I like your conclusion: 'Due to the 13-1 expansion engine ratio, (high compression engine) it started hesitating and having a rough start transition from hybrid to ICE power.'
    one keyword here: atkinson cycle/
    (& the ice gets revved up to like 800rpm neway before the ignition gets activated)
    I wonder where you 'researched' that?
    probably a good idea..../
    that has nothing to do with the problems you mentioned/
    not a good first post to introduce yourself..... just saying/
    alanclarkeau likes this.
  3. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Using high octane fuel should not lead to engine problems. Premium fuel is only more resistant to knock. Engines that do not need premium fuel but that are run with it suffer no adverse effects from that.
    Whatever you experienced, it is not due to the premium part of the fuel. The fuel may have been bad, you may have other problems, but the advice not to use premium fuel is bogus.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    I use premium fuel only from day one, no issues at all, and Toyota states in the manual use 87 or HIGHER.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I'd suspect you got a bad batch of fuel, as premium wouldn't cause those symptoms. Or maybe it's due for new plugs or something anyway. I'd talk to TOYOTA before jumping to conclusions.
    Gen 3 in Australia, TOYOTA specifies Premium 95 fuel (unless absolutely unobtainable as a temporary solution).
    My Gen 4 2016 specifies "Research Octane Number 91 or higher" - 91 being our regular here.
    Ernesto Chavez likes this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm going to agree with you...in this specific manner.
    I run regular fuel in The Prius because it's recommended- and I can.
    A huge benefit with The Prius is not only fuel efficiency, but that you can also run on regular. Why should I throw that benefit away?
    That being said? Occasionally. maybe 2-3 times a year, I run a tank of premium, I also will run a treatment of fuel cleaner...Techron.
    I don't feel it does any damage, even if any benefits I may be imagining are placebo related.
    The Prius can run on regular. So I mostly, nearly exclusively- run regular.
    It's ALWAYS cheaper than Premium, and even when I run a tank of Premium, I don't feel any real benefit.
    If The Prius required premium fuel that would be different, but the reality is just the opposite.
    I'm going to enjoy the great fuel economy AND the economy of being able to fill up on regular.
  7. bisco
    52,847
    could be you need to disconnect your 12v for a minute, since the ecu was planning on regular.
    #7 bisco, Jul 1, 2016
  8. Ernesto Chavez
    24
    As you stated, I am a newbie to hybrids. I am very impressed with the toyota prius. The 87 octane did solve my heavy rough start issue. Unless ExxonMobil had water in their fuel??? Anyhow, Next step is to clean the egr/pcv system as routine maintenance. What advice can you give on "the only sticking to 20Wt" motor oil? I read that too heavy of an oil will also cause hard start conditions. I live on a usually hot and humid texas coast. I'd prefer at least use 30Wt synthetic oil.
    #8 Ernesto Chavez, Jul 2, 2016
  9. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Your mileage won't be anywhere close to what it could be if you use Toyota's recommendation for your conditions.
  10. Ernesto Chavez
    24
    By hopefully experienced people like you on this website...
    booke02 likes this.
  11. StarCaller
    1,284
    733
    I wouldn't run 0w-20 where you live/
    in fact, I run in all my cars 0w-40 (& new mexico is probably most of the time not as hot as south texas)
    what sense does it make to get 2mpg more but the engine dies on you way earlier than with using thicker oil?
    guess it all depends on what you want..../
    better save than sorry/
  12. fuzzy1
    10,706
    No, this is not a high compression engine at all. The true compression ratio is very ordinary (8.5 to 9?).
    The expansion ratio is different because of the Atkinson cycle.
    #12 fuzzy1, Jul 3, 2016
  13. Ernesto Chavez
    24
    True, that is why I posted 13:1 EXPANSION ratio. Some ppl think it is a higher compression engine. Whatever tickles their fanny...
  14. ChapmanF
    19,019
    Am I old enough to be reading this forum?
    Mr. F and GG707 like this.
  15. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Actually I bet that is incorrect. I don't have a gen 3 to check the manual but I would bet that it says to use 87 octane, not "regular" because regular varies. Here in Colorado, "Regular" is 85 octane. In Montana "Regular" is 85.5 octane. At lower elevations "regular" is 87 octane. Do you run 85 octane at higher elevations or do you stick with the recommended 87? I've emailed Toyota, Exxon and Shell asking this question, they all say 87, no lower, regardless of altitude. I've only owned Chryslers before but they told me as long as I'm staying in the mountain region 85 is OK. Not sure who to believe but I'm running 87 in it for now. It annoys me because my gas savings isn't as much as I had expected because of it. I would bet that the majority of cars in Colorado are fed 85 octane and apparently without problem.
  16. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I have not seen a problem with Premium, but my Bentley Publishers Toyota Maintenance Guide (for Gen2 Prius) says Premium can cause harder starting.
    #16 wjtracy, Jul 4, 2016
  17. Mendel Leisk
    42,343
    You've made yourself a Gordian Knot there, fugedabout it, just go for the regular pump. Which I think you're saying anyway.
    In Canada the gas rating system don't jive with what's in the manuals, I think that's actually in our constitution, everything we do is like that, lol.
    So I just think regular, forget everything else. :)
    Montgomery and CR94 like this.
  18. qdllc
    qdllc Senior Member
    1,377
    400
    What's funny to me is that I often run "regular" in my sportbike. A guy who did GP racing told me the high octane really didn't do much unless you need every HP the motor can crank out. For my use (casual touring), he said I'd not see a big improvement for the cost...especially if I ran fuel system cleaner on a regular basis. For all the talk of "octane," chemically it's a very tiny portion of the gasoline molecule/formula.
    douglasjre likes this.
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I run premium every winter, soon as they bring out the "winter formula"
  20. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    But what's your rationale?
    I can see the potential issue with harder starting of Premium would be less with Winter blend.
    In your region, winter blend could have more MPG than Regular, but not in my region (RFG).
