Do Plastic Calipers Jam Up?
Discussion in 'Gen 3 Prius Main Forum' started by jimolson, Nov 3, 2024.
  1. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    I did a brake job on my 2010 yesterday: new pads and rotors from Rock Auto. The old rotors didn't look too bad for the mileage. The pads were pretty worn down, though.
    While I had the calipers off I greased the slides. The rubber boots on the pistons seemed to be ok.
    Today one of the wheels overheated at 60mph, but not hot enough to melt the wheel cover. The new rotor had turned a pretty shade of blue by the time I smelled it and pulled off the interstate highway. Good thing I had the windows open.
    These calipers, like all Prii, have injection molded plastic pistons. In the old days (pre-Prius) it was common for metallic pistons in calipers to seize in their bores when corrosion on them was severe.
    Does the same seize up thing happen with these new plastic caliper pistons?
    When I order a new rotor and pads tonight should I also purchase a new caliper? It's possible that today's jamming is not due to caliper jamming but due instead to faulty reassembly on my part. My 72 year old back was killing as I worked sitting on the garage floor.
  2. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    Can you post pictures of the caliper in question?
  3. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    Usually when I do these all I do is take my channel locks and rotate the piston in the boar assembled with the bore and the piston and the seal and the rubber and all on I just grabbed the piston and turn it say a half a turn of the diameter of the piston and then squeeze it down with the chanel lock pliers. That usually frees up any funny business unless everything work on reassembly I'm not sure what's happened here obviously you didn't think you need to bleed the brakes maybe that's something that needs to happen on that one side possibly but generally no the composite Pistons don't generally seize in the boars because they're not rusting and rust even if the caliper metal was rusting it can't stick to the composite piston
  4. ChapmanF
    19,010
    Not quite all Prii. The pistons were metal in gen 1, and the phenolic pistons were introduced to Prii in gen 2. (They go way further back in some other vehicles,)
    The pros of phenolic pistons are: they don't rust/corrode, and they're much less heat-conducting than metal pistons so less braking heat is carried back to the brake fluid. One con is that they can (at least the early formulations) swell, and become tight in the bore that way. The swelling seems to be pretty rare and happen only in very special circumstances; ordinarily they're very trouble-free. I do remember at least one PriusChat thread though where there was a swelling problem.
    This study appears to suggest that it's dampness/humidity that swells them (when they swell). The problem was pronounced in RVs, which can sit unused for long periods soaking up damp, and don't see enough regular use to heat the pistons and drive the moisture back out.
    These days, if I rebuild a caliper, or even take one fresh out of a box, I will test the piston return on the bench before even putting it on a car, as described in this post. Insufficient return of the piston can cause dragging and overheating, whether it's because of rust on a metal piston, swelling of a phenolic one, hardening of the square-cut rubber seal, or any other cause.* (Then, of course, once it starts, it's going to cook that rubber seal anyway, even if the original cause was something else.) So a quick check of the piston return lets you catch that problem right away and deal with it, whatever turns out to be causing it.
    * and yes, I have seen even a fresh-out-of-the-box reman caliper with no piston return. The piston and seal were both new and nothing was corroded, but the rebuilders don't always seem to get the right magic amount of friction between the rubber and the piston. In the problem one I saw, they used a metal piston with a very smooth mirror finish. In a caliper from Toyota, by contrast, even the metal piston had more of a matte surface, and the seal gripped and retracted it avidly.
    #4 ChapmanF, Nov 3, 2024
  5. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Thanks to all of you for the responses, especially fellow Hoosier ChapmanF whom I would like to meet someday.
    I expected someone to write that a phenolic piston is actually a weight-saving facade and there is a thin metallic cup surrounding it that moves in unison with the phenolic part. That would suggest corrosion-caused seizing of the piston is still an explanation for yesterday's fiasco.
    But no, "phenolic all the way down." In all likelihood I've made an error re-assembling the brake that caused pad dragging.
    I sat on my clean Dockers on Interstate 465 yesterday feeling a lot of kilowatts pouring out of that hot wheel well, enough to undermine any remaining life in the caliper, especially the phenolic piston and its seals. Ordered another caliper last night online.
    I absolutely hate brake bleeding! It destroys the Zen of car maintenance when you have to go hat-in-hand to your wife asking her to pump the brake pedal. And while she pumps it she'll be whining "you're too old to be working on this sh-t...leaving the garage a mess..."
    On a positive note, I highly recommend driving 3 miles home through your city's side streets at 2mph with your emergency flashers on. You see a lot of urban humanity and roadside detritus you don't see whizzing around on interstate highways. My favorites were the folks who approached me from behind at 40mph and swerved to avoid me in the last 1/2 second.
  6. Tombukt2
    13,853
    2,515
    Durham NC
    Why bleeding ? I just undo line put rubber cap on line. Remove old caliper . Take new syringe on new fluid till it pops out of loose bleed screw. Hand close bleeder. Uncap hose it's dripping fluid offer it up to new caliper that's full . Tighten . Crack bleed see air bubbles just a few popp pop pop and now clear. Should be no bleeding now . You're I guess just letting it all run out or such?
    BiomedO1 likes this.
  7. bisco
    52,834
    your post made me laugh jim. i can remember 40 years ago, my 9 month pregnant wife pumping the brakes on our ancient valiant in the middle of winter while i bled them.:p
  8. ChapmanF
    19,010
    Definitely the seals and probably the phenolic piston. Rest probably ok.
    If the injured caliper was an original Toyota, I would probably buy Toyota's rebuild rubber kit (everything you need but not the piston) and piston and put it back together, and probably have a better caliper than an aftermarket. If it was already an aftermarket caliper, then yeah, might as well replace it with another one, and let the aftermarket guys rebuild the core you send back.
  9. BiomedO1
    BiomedO1 Senior Member
    4,582
    2,405
    Left Coast
    the key is capping that brake line, when you take it off. then prefilling your new caliber.
    I do a variation of that procedure with a vacuum pump, to pull fluid through, rather than rely on gravity.
    Brake Bleeder and Vacuum Pump Kit
  10. Tombukt2
    13,853
    2,515
    Durham NC
    Well whatever you do doing one caliper at a time you shouldn't have to do any bleeding The stuff is running out of the hose when you undo it All you got to do is put a little rubber cap on it have it in my pocket when I start the job and then when I screw the new caliper on I just let it sit there and crack the fitting and wait a minute or less and it fills the caliper and comes out of the bleed screw then I just close it leave the caliper hanging and put my brake pads in in the springs and all the nonsense and then drop the caliper on go do the other side I try not to be sucking on the stuff with a mighty vac that can pull air around the threads of the bleed screw but that's neither here nor there was just another less amount of tools I have to pull out to go to the side of this car but anyway so you've got the idea and then there shouldn't be any bleeding just saves the step that isn't needed
    mjoo likes this.
