Do Prius Brake Lights work when the car is Off?
Discussion in 'Generation 1 Prius Discussion' started by Pri-Eye, Nov 12, 2015.
  1. Pri-Eye
    Pri-Eye Junior Member
    34
    Metro Detroit
    2001 Prius
    The brake lights work when I step on the brake even though the car is off and the key is removed.
    Is this normal or do I have a bad brake light switch?
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, brake lights are designed to work all the time.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I've noticed that on all cars I've had here (USA). I lived in the UK until 1983, and on every vehicle I drove on that side of The Pond, the brake lights would only operate when the ignition was "ON". I guess it must be a safety thing? (in USA, anyway) :confused:
  4. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    Thanks for the answer!
  5. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Many years ago, I watched someone run from a cop, up a side mountain road, in the dead of night. Turned off his lights, went up the hill, turned off the car, and had his foot on the brake pedal... Stuck out like a sore thumb!
    bwilson4web and usnavystgc like this.
  6. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    I would be interested to know if they could be disabled via a relay when the car is off, without setting a code.
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    Why would you want to do that? They are purposely wired that way for your safety.
  8. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    How do they provide extra safety if the car is off and not moving?
    If any lights should work when the car is off, it should be the hazard lights only.
    Unless I'm missing something. I can't think of a situation where the electrical system would be compromised and the brake lights would be better than hazard lights.
    Any thoughts?
  9. fuzzy1
    10,707
    I'm think more of traditional non-hybrids that are turned off, but moving anyway. E.g. a car shut off to get control of a runaway engine, or being moved or rolled after engine or other system failure, or even the extreme (and illegal) hypermiling method of engine-off coasting.
    FWIW, the Prius can be put into the first situation. Remember the recovery methods discussed during the Toyota Sudden Unintended Acceleration fiasco a half decade ago.
  10. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    Well that's a pretty good point!
    I didn't think the unintended acceleration issue affected the Classic 01-03 Prius. Does it?
  11. fuzzy1
    10,707
    At some level, it affects all cars. The great majority of SUAs are pilot induced, and make it very difficult to rule out the possibility of machine induced events hiding in the mix.
    #11 fuzzy1, Nov 22, 2015
