Do Prius track how often you perform maintenance?
Discussion in 'Gen 2 Prius Main Forum' started by DLC82SV, Jul 16, 2018.
  1. DLC82SV
    DLC82SV Member
    241
    119
    Do these cars keep track of when they are serviced? I do not want my car lighting up light a Christmas tree and freaking out because it thinks it's being neglected. For example, some vehicle's keep track of oil life etc. Will an 08 prius light up and go into limp mode because it thinks it needs something, or only if there's something wrong? TIA
    49,587
    welcome!
    no. there is a maintenance reminder on the mfd every 5,000 miles that has to be reset. and there is a hidden service menu you can program for your own service schedule.
    but the only time a dash light will come on is when something is broken.
  3. Mendel Leisk
    38,789
    No way. Car's have maintenance minders, some dead simple odometer counter (like the US Prius, we don't have that even in Canada), some more involved:
    Honda's Maintenance Minder, which appears to be monitoring several factors that might effect oil life, and counts it down accordingly. It doesn't just say maintenance due, it also says specificall what's due (really cuts down on dealerships "padding" the maintenance schedule, btw), through codes, letters and numbers, and it's everything that needs doing. B12 for example, would be oil and filter change, rotate tires and change the air filters:
    (The above's for a 2010 Pilot, some FWD stuff, btw.)
    But, this still is just notification, and when you set it, it's reset. And there's no way the car can tell what you have or haven't done. It might log what notification have been shown in the past, but I very much doubt that too.
