Do the brake pads really have two sets of shims?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by sylvaing, Apr 15, 2024.
  1. sylvaing
    sylvaing Active Member
    1,028
    425
    while doing my first spring cleaning of the brake pads on my 2017 Prime, I noticed that all the pads have two sets of shims on, one on top of the other. Is this normal for this car? It's the first time I've seen brake pads like that.
  2. Mendel Leisk
    38,657
    Are Gen 3’s got dual layer shims front and rear. IIRC all our past Hondas were similar.
    the outer shim is typically smaller than the inner one, which helps if you’re scratching your head.
    sylvaing likes this.
  3. sylvaing
    1,028
    425
    Thanks. I searched the web and came to the same conclusion.
