Do the brakes need adjusting?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Drifter, Jan 2, 2007.
  1. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    My dealer adjusted and cleaned mine every 15k while under warranty. I could tell a big difference in the braking afterward, BUT.... I also lost gas mileage until they got looser again. Pro's and con's of adjusting self adjusting brakes. Self adjusters aren't perfect.....:rolleyes:
  2. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    no response needed
  3. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    And conveniently I have just read through Hobbit's brake pages. The problem now is that his dissection and testing of how the rear brakes adjust is in DIRECT opposition to what was written here. Hobbit's write up shows they adjust NOT with the parking brake but with the regular hydraulic piston. In short, every time the shoes are pushed out by the hydraulics (but NOT when activated by the parking brake) a lever will click the adjuster IF the shoes move far enough out (which they will do occasionally as they wear).
    So NOW what do we do? We have the much trusted Galaxee (and DH) saying it is the parking brake and Hobbit, with detailed pictures, (including a not so comfortable 'testing' position:) ) saying just use the brakes, the rears self adjust.
    :eek:
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    toyota didn't tell their techs that this was a new brake adjustment mechanism. hobbit provided the evidence, DH saw and said ok that must be it. i tried to edit my post above to eliminate some of the confusion.
  5. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    You mean early Prius models had non-self adjusting breaks?
  6. galaxee
    9,810
    471
    MD
    i mean it's different from their usual mechanism which is linked to the parking brake.
  7. Richard F Conroy
    Richard F Conroy New Member
    Tucson, AZ
    I have a 2014 and a 2004 Prius. The 2004 had 174,000 miles on it, so I decided to replace the pads and shoes. When I disassembled them, they were both only worn about 1/2. I replaced them anyway, as I had already bought the parts. Neither the rotors nor the drums were stepped or grooved, and measuremens showed they had ever been turned. I consider that a fantastic brake life. They were probably worth another 25,000 miles (?)
