Do the mileage figures make sense?
Discussion in 'Gen 4 Prius Main Forum' started by kgall, Nov 25, 2015.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    It still doesn't quite make sense to me, unless the tire effects are huge, or there are some differences between the 2 ECO and other models that we don't know about--and I can't really figure out what they might be.
  2. Navigare
    Navigare Active Member
    312
    138
    Netherlands
    Old test, there's new technology around that IS getting the winter certificateMichelin CrossClimate launched is this a game changer - TyreReviews
    Goodyear Vector 4Seasons Gen 2 Press Release - TyreReviews
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    From what I've read they say Dunlop Enasave, and as someone who had driven on one for 500mi (comes OEM on Mitsu Mirage) can say for sure, it is the biggest POS you can find. Mirage managed 0.73 on skid pad, and 80% is due to Dunlop LRRs. Switching them out to normal tire (unfortunately there isn't any other LRRs) in Mirage size, had shown more than 10% MPG loss, so they are very good at LRR at expense of grip. Dunlop LRRs are rated AA in LRR and C in grip by Japanese tire rating system, and the best LRR Bridgestone EP001S rated AA/A in Japan and A/A in EU labeling system.
    kgall likes this.
    52,849
    i think it's because the '16 is based on the new epa test, while the '15 wasn't.well, we know about the weight difference, the rear wiper and the tyres model and higher inflation. it doesn't take that much to gain 4 mpg, but there might be something else toyota hasn't told us yet.
  5. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I know new candidates did very good (GoodYear, Michelin, Nokian), but the problem is:
    - they are pricer (80€ per set difference)
    - after 2 years (44k km) winter traction would be questionable
    - fuel consumption would be around 0.2 l/100 km higher
    - still not optimum for 50°C tarmac in summer or -20°C in winter (tire tests are not done in extreme conditions)
    With two sets I get:
    - better traction
    - better longevity per tire
    - better fuel consumption
    Both options cost about the same (tire change costs me 25€) if you are doing 20k km/year, the less km you drive all season option looks better and vice-versa.
  6. cyclopathic
    3,292
    547
    2014 Prius c
    this is misleading it is still the same test. EPA just issued guidelines on how it should be executed. So if you weren't cheating in a first place like Hyundai or Ford there will be no difference. Or you think Toyota cheated too?
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This is not completely accurate.
    there is at least one change in the procedure itself and it is in the 'road load force' (as a function of speed) that the manufacturer provides to the dyno test to simulate road load (aero, real road rolling resistance etc.).
    This is conducted by the manufacturer on the road by coast-down tests that now should be conducted at various speeds up to 50 mph (previously it was up to 70 mph).
    Experts say it may influence the fuel economy result of the EPA test.
    #67 giora, Dec 3, 2015
  8. cyclopathic
    3,292
    547
    2014 Prius c
    if you look at excel data on EPA site load had been reported not something new. I will check but coast down data also state the procedure used, and they accept both at this point. 50 vs 70 is interesting discussion as one would favour city and other highway. If they reduced speed the easiest way to counter it by pumping up tires.
  9. bisco
    52,849
    i don't know anything about the new testing parameters, i'm just going by what i have read here. are you claiming to know for sure that a car that tested 30 mpg in 2015, will still be 30 mpg in 2016? i haven't read anyone else saying that.
  10. Mendel Leisk
    42,343
    It'd be really nice if there was some standardized testing method that could be quoted, regardless of how wacked out it was, just so there'd be some constant for comparison.
  11. bisco
    52,849
    agreed.
  12. Trollbait
    12,825
    The EPA test cycles aren't changing. Neither is the way the raw results are adjusted for the window sticker.
    Sounds like much of the changes are in regard to the rules on the condition of the test vehicle and its equipment, and the pre-test procedures, or that the EPA is going to be stricter about them. It could just be clarification of some of the rules. We've all heard about Hyundai's 'cheating' on the MPG. I used the air quotes because Hyundai's error happened due to a misunderstanding of these current rules, and they weren't fined has fine as if their actions were intentional.
    The biggest change is the higher starting speed for the coast down test to determine the road load for the test equipment. This might make a change to the results, but we won't see how much until the data is out for a model that was tested under both procedures.
    Any changes will be easier to see in a high fuel efficiency car like the Prius. I expect some, but not enough to get the 4% improvement to 10%.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    That is the biggest advantage of the NEDC test cycle over the adjusted EPA one. Although far from real world driving but at least based on known parameters without adjusting fomulee and can easily repeated by a third party and good for comparison.
  14. Trollbait
    12,825
    The EPA posts the test cycles.
    Detailed Test Information
    The city and highway ones are the main cycles. The other three are used for adjusting the window sticker. If you don't care for adjustment and whether the posted number is close to real world, then look up the model's CAFE number. That is just the unadjusted city and highway test results.
    energyandair likes this.
  15. bwilson4web
    16,533
    It should improve the precision of the V**2 coefficient but not change the value.
    Does anyone have a link to the new EPA testing procedure?
  16. bisco
    52,849
    what is in troll's post above yours?
  17. cyclopathic
    3,292
    547
    2014 Prius c
  18. Trollbait
    12,825
    All we got is some reports about changes to the rules. I think I summed up all they have said.
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    bwilson4web likes this.
