Do they make a bra for the 2012 Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by savingtheearth, Jul 4, 2012.
  1. savingtheearth
    savingtheearth Junior Member
    82
    LA
    Can't find one anywhere- most just make up to 2011. And is there a difference in the front between the 2011 and 2012?
    Thanks!
    Happy 4th of July!
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Yes there is a difference with the MY 2011 and 2012 front ends. The overall shapes are the same but the lower grill opening and turn signals/DRL's, fog lights are in different spots and they are shaped different from the MY 2010-2011 on the 2012's.
    Posted from my iPhone via the Tapatalk app.
  3. ockevin
    ockevin Active Member
    493
    148
    Orange County
    Just one question... WHY ??????
    Its so 80's
  4. savingtheearth
    82
    LA
    Yes- I don't like car bras- but going to go on a long road trip and wanted to save my front end the cheapest way. Won't use it after the road trip. Anyone have any other suggestions? Thanks!
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yeah.......Get a rental :D
  6. ES44AC
    ES44AC C.A.U.S
    319
    77
    Or you can tack some contact paper all over the front end.... I actually have heard of people doing it in a pinch. Might be Ok for bug guts but for stones? I doubt it.
  7. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    There's a temporary clear bra film that you can get. I believe Griots garage sells it.
  8. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    Yes there is, it's called a 3M Clear Bra. I had my entire front ended done to protect it. :)
  9. ES44AC
    ES44AC C.A.U.S
    319
    77
    A 3M Clear Bra is not temporary it's semi-permanent until you damage it or replace it.
    Calling it temporary makes it sound like it needs to be taken off after a few days or weeks. Yes you can take it off to replace or repair it but in all the cars I have had the used the product on I've never replaced it for reasons other than damage.
    Personally I prefer to use the 3M Venture Shield, it's similar to the regular 3M but is very smooth and doesn't have the orange peel effect that the plain 3M does.
    I think the OP is looking for one of the black vinyl bras that you can put on and take off as needed. They are ugly and once they get wet if left on the car it will damage the paint. Especially if the finish gets dirty underneath the bra.
    A clear bra eliminates any of this nonsense but I don't recommend you try and install it yourself, get a professional!
  10. savingtheearth
    82
    LA
