Do we have a recommendation for a bluetooth phone?
Discussion in 'Gen 2 Prius Audio and Electronics' started by clifford, Nov 15, 2006.
  1. clifford
    clifford Member
    156
    Thank you for giving me your recommendation on a new phone for my 2006 Prius.
  2. withersea
    withersea DNF is better than DNS
    1,162
    TN
    I've had good luck with a Motorola V557 and a Nokia 6160i through Cingular. Both work well with the car.
  3. New Revelation
    New Revelation The Master Captain
    180
    Liberty, TX
    I have the Motorola RAZR V3 with Cingular and it pairs nicely with my car. Verizon I heard is good but seems to have restrictions regarding the phone book on some of their phones. Other than that you can't really go wrong.
  4. John Baker
    John Baker New Member
    <div class='quotetop'>QUOTE(Hopeful Future Prius Owner @ Nov 15 2006, 08:54 PM) [snapback]349946[/snapback]</div>
    I have had good luck with the Sony Ericcsson from Cingular. It was a real pain setting up the one-touch dialing, because it only takes the first number listed for each person. Once you figure that out, it works well.
  5. Frank Williamson
    Frank Williamson New Member
    <div class='quotetop'>QUOTE(clifford @ Nov 15 2006, 06:37 PM) [snapback]349908[/snapback]</div>
    I've been using the Verizon Crzr with a 2007 Prius for about two weeks now. It's a snap to setup, just follow the onscreen prompts and the Crzr pairs every time I get into the car. Most people have no idea I'm using the automobile microphone with bluetooth so it's excellent in that regard, they hear no echo or other problems and I hear them perfectly. BUT ---- Verizon is trying to get every nickel they can out of you and refuses to implement the automatic phonebook transfer feature. So you'll have to manually type every name and phone number into the Prius phonebook. Except for that irritation, the Crzr works beautifully with the Prius.
  6. rmblaster
    rmblaster New Member
    Orange county , CA
    We have lg 5300 and lg 8300 from verizon both work and sound great no problems with either and a cinch to hook up don't think the phone book transfer works but i haven't tried it
  7. dmarcus123
    dmarcus123 New Member
    33
    <div class='quotetop'>QUOTE(clifford @ Nov 15 2006, 10:37 PM) [snapback]349908[/snapback]</div>
    Blackberry 8700 (from Cingular in my case) - no problems.
  8. Prius07Pkg4
    Prius07Pkg4 New Member
    <div class='quotetop'>QUOTE(rmblaster @ Nov 19 2006, 06:55 AM) [snapback]351666[/snapback]</div>
    <div class='quotetop'>QUOTE(Stratoliner @ Nov 18 2006, 11:24 PM) [snapback]351627[/snapback]</div>
    I have LG VX8300 and Prius 07, Complete Phone book transfer does not work but you can transfer 10 names at a time. Say you have 81 names on your phone book you need to transfer 9 times.
    It call Send Name Card under (Bluetooth --> HandsFree ---> Options ---> Send Name Card --> Mark 10 name -->Done
    If you mark more than 10 it will notify you!!
  9. clifford
    clifford Member
    156
    <div class='quotetop'>QUOTE(Prius07Pkg4 @ Nov 19 2006, 02:04 PM) [snapback]351730[/snapback]</div>
    Thanks for your reply. I have a two year old lg and like it. I am now really close to choosing the new vx8600 lg phone. I would assume that it should be just as good of a fit but it is really new.
    Thanks for your input. :)
  10. aaf709
    3,841
    The Verizon e815 works well. As mentioned earlier, the inability of sending the phonebook is a big problem. I got a non-Verizon BT phone off eBay, put the phonebook into that and set the phonebook to the Prius that way. I have a 2005, so I can't enter the numbers manually.
  11. eagle33199
    eagle33199 Platinum Member
    5,122
    267
    2015 Prius v wagon
    My LG works just fine... I want something with a few more features, but i'm waiting till jan-feb time frame for the iPhone. i figure it's gotta have built in everything!
  12. Gen2
    Gen2 Member
    319
    My Motorola SLVR and wife's RAZR pair up to the Prius without a problem. Phonebook transfer is not fantastic but it works.
  13. fern
    fern New Member
    I have the Blackberry 8700c (Cingular) that I use in my 2005 Prius. I have one problem where the bluetooth randomly gets disconnected and then immediately connects again. It is very annoying because it sometimes about twice every minute. I used to have a Motorola v551 in the past and it never had this problem so I'm thinking that this might be a Blackberry problem.
    Let me know if anybody else is having this problem :unsure:
    ~fern
  14. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    I have the Sony Ericsson (Z520A) with cingular with no problems.Very good bluetooth range!I remember once leaving to go some where and made a call while leaving my driveway and while talking realised my cell phone was still in my house :lol:
  15. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    I have a Cingular Nokia 6102i, and it works fine. As with most bluetooth phones, I had to send the phonebook one name at a time, but it was relatively painless since I don't have a large phonebook.
  16. crypter
    crypter New Member
    49
    I have a Verizon Treo 700p. The bluetooth works fine, I will try the phonebook data transfer soon - wish me luck :rolleyes:
    cc B)
  17. cwerdna
    cwerdna Senior Member
    12,539
    2,104
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(Gen2 @ Nov 24 2006, 10:25 PM) [snapback]353866[/snapback]</div>
    Which carrier? That can make a HUGE difference.
  18. vincemiccio@comcast.net
    [email protected] New Member
    We took our 2006 Prius and our Verizon RAZR V3c to the Verizon techs and they told us their version of the RAZR could not transfer our 300 contacts from the RAZR to the Prius. :( :( :(
  19. busdriver
    busdriver New Member
    Can you tell me what menu you are using in your info for transferring 10 names at a time. I have the identical car and package you have and I can't find the menu you describe. Please help.
    Fred :angry: <_< :( :blink:
  20. clifford
    clifford Member
    156
    <div class='quotetop'>QUOTE(busdriver @ Dec 9 2006, 02:33 PM) [snapback]359773[/snapback]</div>
    Yes I would like to know that also.
    Ok so I did buy a lg vx8600 Verizon phone :)
    At this point I have just loaded, manually, a few phone numbers. I have not transfered any numbers via the contacts list nor have I loaded voice dailing.
    Any workable hints here would be appreciated.
    So far the bluetooth of the Prius (four calls both directions) works great and I really like it. Just need to transfer more numbers. I know from previous posts that Verizon does not enable the transfer of the entire contact list. :(
Loading...
