Do we really need the12 V Battery vent?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paul Braathen, Jan 26, 2018.
  1. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If they did not need a vent, why would they have a emergency pressure relief valve?
    LasVegasaurusRex and pilotgrrl like this.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Incase some moron tries to charge it with a 48 volt charger.......just for instance.
    Or some other situation where the gas is produced faster than it can re-combine.......which does not happen in "normal" use.
    I think you are smart enough to figure that on your own, however.
    Please just stop with the trolling.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am not the one recommending that a blatantly unsafe idea is OK. It is not safe.
  4. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I wonder how they manage to put the mobility scooters with two of these AGM batteries in seniors houses and recharge them over and over again and not vent them to the outside.
    SFO likes this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I have not seen a scooter with an interior.
  6. Dxta
    Dxta Senior Member
    1,943
    769
    Lagos
    1970 beetle, and still operational? Does that beetle still pass emissions tests and all that? Its surprising to me though.
    pilotgrrl likes this.
  7. Mendel Leisk
    42,271
    I don't think classics have to pass emission tests, that's asking too much?
    My folks had a 58 when I was a kid. I found an owner's manual source, cobbled a pdf:
    '58 Volkwagen Beetle Owner's Manual | PriusChat
    An incredible level of mechanical detail in the above, and under 100 pages. It doesn't have to deal with frivolities though, like Navigation, Entune, or even gas gauge, lol.
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The 70 has the standard gas gauge. My parent's 61 had the optional gas gauge + the reserve tank lever. Do VWs still mark the empty end of the gas gauge as "R", as in "Reserve"?
  9. Mendel Leisk
    42,271
    Not sure. Yeah, I think if it started gasping, there was a lever you flipped, to switch over to reserve.
    Ah, here we go:
  10. Sam Spade
    2,036
    1,024
    2017 Prius c
    I said no such thing.
    Are you off your meds lately ??
  11. frodoz737
    frodoz737 Top Wrench
    4,793
    2,560
    33
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Sam lets pretend I was recommending driving without the front and rear bumpers, because in normal use you never need them.
    You would object that on the bad days when you did need them, not having them makes it infinity worse. I am arguing that when bad things happen to your lead acid battery, not having the vent makes it much worse.
    Hydrogen is explosive between 16% and 60% in air. I do not believe that even if the entire battery became H2, that it could be 16% of the passenger compartment, I do not think the car will explode.
    Hydrogen is flammable between 4% and 95% in air. I do believe that H2 fumes from the battery could exceed 4% inside a Prius. (A battery outside, under the hood will never make the air 4% H2) More to the point, Toyota's engineers believe this, so they added a vent tube.
    You argue that unless something bad happens, you do not need that tube, but that is true of much of the car. Unless something bad happens we do not need a emergency brake, or diagonal braking in the hydraulic brakes The car really does not need 4 way flashers unless something bad happens, The spare tire is dead weight unless something bad happens, etc.
    The truth is, something bad is going to happen to some Prius owner, and I would like to minimize his bad day. Yes, he wrecked hi Prius and shorted out the battery but the car did not burst into flames. Still a bad day.
  13. ChapmanF
    18,960
    a good thing, too, that, as we don't have diagonal braking in the Prius.
    (ducks and runs)
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I may have shown my age. They were a big deal in 1967.
    pilotgrrl and m.wynn like this.
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    You can believe whatever you want but that doesn't change the facts.
    An AGM battery typically does not leak (much) even if the case has a significant crack.
    An AGM battery typically does not accumulate enough hydrogen to make a flash any bigger than striking a match.
    There are HUNDREDS OF THOUSANDS of AGM batteries in other cars and trucks (maybe millions) and most have no connection for a vent tube. The experts who design and build them must think that they are not necessary.
    And continuing to beat that dead horse benefits nobody.
    SFO likes this.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Nor do I, when mounted under the hood, I suspect the Gen 4 has no vent tube. Only when in an enclosed space could the hydrogen build up to a dangerous level. For better or worse, Gen 1 to Gen 3 do place it in the passenger cabin, so Toyota uses a vent tube to prevent hydrogen build up in that enclosed space.
    I have shown BMWs with batteries in the passenger space and they also have vent tubes, can you show any of your 'HUNDREDS OF THOUSANDS of AGM batteries in other cars' with no vent tubes from the factory, that are in the passenger cabin?
    #56 JimboPalmer, Mar 19, 2018
  17. Sam Spade
    2,036
    1,024
    2017 Prius c
    Give it a rest please.
    You have been arguing all kinds of incorrect information about AGM batteries without any mention that you are still talking about ones designed to be used inside the passenger cabin.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You mean the ones used in a Prius? This IS PriusChat.
  19. Mendel Leisk
    42,271
    Experienced that scene in a full theater, with the family, and the audience just went nuts.
  20. fuzzy1
    10,687
    And the facts are, a mother and child were killed in another brand car, poisoned to death by a malfunction, and a battery venting error on a battery mounted within the passenger cabin.
