DO Wheels from other car fit Prius?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by kevinlaul, Dec 5, 2007.
  1. patsparks
    10,664
    569
    Adelaide South Australia
    You will find these wheels have 2 different pitch circle diameters. I had similar on my Camry, which by the way would I think have fit the Prius. The Prius has the same stud pattern as the early 90s Camry and I think the current Corolla so wheels should be easy enough to get, just check the offset.
  2. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    I thought that the Scion's tC wheels will fit too... no?
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    You'll find lots of info on the stock and really nice Volk wheels here: http://priuschat.com/forums/showthread.php?t=38512
    BTW, for those not experienced in aftermarket BLING, the Volk wheels priced at $1500 - $1600 are not expensive, for what you get. I wish I could justify purchasing them, because at 10.6 lb per 16" wheel, with Nokian WR G2 tires mounted in a 205/55 R16 size, they would be my "dream wheels".
    I need someone to rip off my stock wheels. ;)
  4. kevinlaul
    kevinlaul New Member
    OK, I've got wheels & tires and they are on. Aside from the stud road noise (minimal), it' great. Mileage has not changed (+ or -)
    The Wheels were bought off eBay,
    *2007 Toyota Corrola black steel wheels $82.00 includes S&H These are center hub fit as well as lug nut (normal lug nuts 5 for $7.00) so there is no problem with bearings.
    * Studded winter tread 15" tires that look like I could climb a ski slope. $182.00 (tires, studs, stem valves, spin ballanced, labor)
    Total= $271.00, peace of mind Priceless, far less than ONE of the OEM wheels my Toyot dealer tried to sell me @ $386.00 + 6% tax
    Thank You ALL
  5. infogeek
    infogeek New Member
  6. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Good thread to research spare tire for Prius.
